Headlight Restoration
Does anyone have a recommendation for Headlight Restoration?
I mean a product or kit that has worked well to fix the surface flaking that seems to be normal on Crossfires?
My car has flaky, etched looking areas on both headlights. There is no "yellowing". It seems to be an environmental plastic corrosion issue.
Re: Headlight Restoration
I've used Meguiar's headlight refurbish kit that includes, sand paper, Wool pad for a variable speed drill, Plastic X, micro fiber towel. You should use a spray detailer to "wet" the headlight surface before and during the process.
Meguiars also sells a UV polish to retain the new look for a longer period of time. For best results, read the instructions or go to Meguiars website for this procedure.
It works great, if done properly.....
Dennis
DTMenace
Later,
And I use Meguiar's PlastX Cleaner & Polish product every 6 months on my headlights, fog lights, & taillights. Keeps everything looking clean & bright. I've owned my XFire for 8 years and never had to use a headlight restoration kit by using the PlastX Cleaner & Polish product every 6 months.
I bought 600, 1000 and 2000 grit sand paper, a plastic spray bottle and a clear coat in the can spray. Taped off around head lights, wet sand with 600 grit and then with 1000 grit, sanded lighter(Pressure) and finally with the 2000 grit, even light pressure. Keeping the lens wet at all times. When done sanding, wiped with paper towel(drying) and then wiped with alcohol. Then taped up area large enough around head lights for over spray and lightly (each coat) did 3 coats on the lens. Look good and a lot better lighting at night. After a couple of days wax them with a good polish. Invest a couple of hours and about $10. Forgot to include that lens will look frosted, after sanding and prepping them, but will clear up when you clear coat them.
Last edited by djohn14296; 05-14-2016 at 09:11 PM. Reason: forgot to include what lens will look like when done sanding and prepping
First off, I would never sand the lens dry as shown in the video. Slow and wet is the way to go. The lens used in the video is not perfectly clear like the Crossfire. When restoring the Crossfire lens, it must be completed really well or every imperfection will show. Been there done that.
And I am told if you use clear out of a can, you are asking for trouble early down the road. You must use a two-part clear if want it to last any time. No clear, just a plastic polish every once in a while after the restore.
Just my opinion. James
A lot of us didn't have that option, bought our Xfires used and head lamps and driving lights already degraded. Glad that worked out for you.....
Anyone can use the protective film. I didn't use it until after I restored the lenses by wet sanding and polishing though in hindsight it would have been a great idea to install the film from new. The argument for using protective film after restoration is that you don't have to repeat the process or continue with periodic repolishing/refinishing. I simply apply wax over the film when I wax the vehicle, though I have no idea whether that has any benefit to the film. With the film you also get the added protection against chips and lens breakage.
Later,
