Tail lights question, possible LED mod
re: Tail lights question, possible LED mod
Nicely done. I've been a big fan of Radiantz for a long time. I have them on my Goldwing and used a clear set in the footwells on my black coupe. I have no affiliation with them but they state they are made in the U.S. (Oregon I think) and are backed by a lifetime warranty. Home
Did you end up pigtailing off the wiring before it enters into the light assembly?
So to clear some things up with this, I ended up swapping those LED bars with another better set from Alpena. These new ones are in the same location, and are red colored too instead of black like the old ones. They are red in LED color as well, and can function for brakes, running lights, and turn signals.
Currently wired only the running/brake functions for them because I need to find another constant current source for the turns on the passenger side. I left that for another time lol.
I wired them into the actual wire harness housing, and just placed them within the pinholes of the correct wire lead. They work nicely, and video is on FB of them running.
I would be able to do it no problem Gary, just name a time and I'll swing by to get them done. Order Alpena 77228 from AutoZone, because they have it on clearance for 19$, while Amazon still has them at 40$.
It also involves a great deal of sitting in the trunk, so I think you'll appreciate not having to do that part lol
Adrian came to the house and installed my LED strips for Rear Brake, Tail lights and turn signals
Lights on /No Brakes
Lights On / With Brakes
Lights On in Garage
Re: Tail lights question, possible mod?
Doesn't look half bad, I did a decent job lol! Now who else wants to jump on this
Re: Tail lights question, possible LED mod
Would it not be possible to get 3 or 4 more LEDs in the strip to cover that blank area on the inside and maybe one more to the outside ?
And it sure would be sweet if they would sweep sequentially inside to outside when the turn signal is on .......
I'd think about trying it if those 2 things could be accomplished .
