LED license plate bulb -- full assemblies
Re: LED license plate bulb -- full assemblies
CBC will have to review your application my friend!
Here ya go
LED license plate lamp FOR BENZ W211 | eBay (CBC search)
http://www.ebay.com/itm/2PCS-LED-LIC...3cd4b9&vxp=mtr
Hmm.. just noticed hong kong.. my vendor has them listed at $200 now.. LOL
Here ya go
Here ya go
2pcs LED License Plate Light Lamp Bulbs for Mercedes Benz W203 5D W211 W219 | eBay
Here ya go
Rather than leave the old lights on the shelf after replacing them with LEDs, why not replace the trunk light with them and add another trunk light while you're at it.
The lights will fit in the hole, they just may need to be held in tight. The LEDs fit perfectly, I'm just not sure of the OEMs.
Or here ( 2pcs 18x WHITE LED LICENSE PLATE LAMP MERCEDES BENZ C CLASS W203 2001-2007 AMG | eBay ), the great grandson auction of the pair I bought, slightly less expensive ($29.83 US, slightly more than what I paid for mine, dang inflation) and still going strong. One note, these sets need to be SLIGHTLY modified (as others in the post have had to do with/to theirs) so be aware they are not 100% without a little modding. I am not sure if the other sets mentioned need the same 'trimming' or not. I didn't HAVE to trim em, did it for comfort/tinkering sake.
Rather than leave the old lights on the shelf after replacing them with LEDs....
I wish.....when removing the OEM's, I first removed the lenses. Then using a plastic trim tool (as to not scratch any paint) I started to "pop out" the black base, but ended up damaging not one, but both of them as they were removed. They bent very easily and ended up cracking apart...regardless of how gentle I tried to be. The new LED's work and look great with no bulb out indicator, but salvaging the original parts was unfortunately not an option....
Thanks for the tip - it worked just as you said and nothing got broke - thanks again.
i did my car full out in led , with the exception of brakes and turn signals, (havent had time) and head lights in HID , the inside trunk light i put a much bigger light over the original housing , and it lights it up great, and 2 194 style bulbs inside the map lights with many leds on them , license plate i used 2 39mm led bulbs and they look gorgeous , and none of them throw a light out code, i avoided error cancelling bulbs since i hate the light output they produce, i get the occasional flicker of light when i hit the window switch , but the light out put is a fine trade off, i need to get prictures up soon!
After installing these lamps 2 License Plate LED Kit No Error Mercedes W211 S211 E Class W219 CLS R171 SLK 55 | eBay (check out the price ha ha ha)
and having the Crossfire back on the road the last few weeks, I have decided that they are little too bright for my liking. So I have ordered a clear carbon fiber sticker that will be applied over the lens to bring the brightness down...http://www.ebay.com/itm/180905052787?ru=http%3A%2F%2Fwww.ebay.com%2Fsch%2Fi.html%3F_sadis%3D200%26LH_SALE_CURRENCY%3D0%26_sticky%3D1%26_sacat%3D0%26_from%3DR40%26_samihi%3D%26_fpos%3D%26_oexkw%3D%26_sop%3D10%26_trkparms%3D65%25253A12%25257C66%25253A2%25257C39%25253A1%25257C72%25253A4392%26_okw%3D%26_fsct%3D%26_ipg%3D100%26_samilow%3D%26_sc%3D1%26_udhi%3D%26_ftrt%3D901%26_sabdhi%3D%26_udlo%3D%26_ftrv%3D1%26_sabdlo%3D%26_adv%3D1%26_dmd%3D1%26_nkw%3D180905052787%26_rdc%3D1I'm hoping this will do the job...otherwise I'm very pleased with the installation.
and having the Crossfire back on the road the last few weeks, I have decided that they are little too bright for my liking. So I have ordered a clear carbon fiber sticker that will be applied over the lens to bring the brightness down...1" x 8" 3D Clear Carbon Fiber Vinyl Sheet Decal Sticker Wrap Sample Piece | eBay
Original Installation of LED Lamp Assemblies
Modified with clear vinyl applied to lenses
The difference is subtle, but where you notice it, is on the body panels on either side of the license plate
My lens for my plate light on the driver side is cracked. There is noticably water getting in there and causing a short to cut the dash light on, even while the plate bulb is on. Some times it does not iluminate and sometimes the light goes out on the dash while im driving. I'm thinking replacing the stock lens is all I need to do with the LED's I bought at Advanced. Otherwise, they seem to work great. Anyone know where I can get the OEM lens with the seal attached? I see bulbs, other assemblies, but not the oem on this thread.
Part Number and Source would be great!
The Mercedes LED assembly just slides in where the bulb snaps in place? is that the easy way to put this to rest?
Performance auto parts & aftermarket auto accessories for your car, specializing SRT4, Crossfire SRT6, SLK32, C32 AMG, VR-4
