lubricate bonnet
Re: lubricate bonnet
Originally Posted by kjwinston
What would you use for a Lubricate on the Bonnet hindges annd Latches? Please.
From Shop Manual
COMPONENT SERVICE INTERVAL LUBRICANT
Door Hinges As Required Multi-Purpose Grease NLGI GC-LB(Water Resistant) (1)
Door Latches As Required Multi-Purpose Grease NLGI GC-LB (Water Resistant) (1)
Hood Latch, Release Mechanism and Safety Latch As Required(When Performing Other Underhood Service) Multi-Purpose Grease NLGI GC-LB 2EP (2)
Hood Hinges As Required Engine Oil
Seat Track and Release Mechanism As Required Multi-Purpose Grease NLGI GC-LB 2 EP (2)
Liftgate Hinge As Required Multi-Purpose Grease NLGI GC-LB 2EP (2)
Liftgate Support Arms As Required Engine Oil
Liftgate Latches As Required White Spray Lubricant (3)
Liftgate Release Handle (Pivot and Slide Contact Surfaces) As Required
EP (2)
Window System Components As Required White Spray Lubricant (3)
Lock Cylinders Twice a Year Lock -Cylinder Lubricant (4)
Parking Brake Mechanism As Required Multi-Purpose Grease NLGI GC-LB 2EP (1)
1 = MoparT Wheel Bearing Grease (High Temp)
2 = MoparT Multi-Mileage Lubricant
3 = MoparT Spray White Lube
4 = MoparT Lock Cylinder Lubricant
BrenLW
08-05-2015 04:53 AM
Fla_Xfire_SRT
06-29-2015 06:51 PM
frenchcrossfire
08-29-2009 08:07 PM
