rear lighting
on
Re: rear lighting
Depending on whether you wish this to be a show car, or a daily driver, you might want to check into X-Pel Technologies protectant film. They will sell it by the sq inch, probably around $50 for enough to cover both tail lights. ( I couldn't find a pre-cut set for the tail lights )
( assuming you are a DIY type )
XPEL Technologies Corp.: Paint & Headlamp Protection Material By The Foot
look under the headlight protector category and measure how much you will need to cover both tail lights.
Re: rear lighting
Originally Posted by JHM2K
The whole assembly needs to be replaced.
Remove the bulbs, and keep those... Search ebay/LKQ for a tail light assembly.
New ones at the dealer are $$$$
Re: rear lighting
Re: rear lighting
Originally Posted by Brendon2022
I have considered doing this also, I was thinking about adding a tinted color to try and cover up the crack. would a tint look ok?
Not quite sure just how legal it is, however. Best check your state laws .....
axnguyen
07-21-2015 11:41 AM
mike28117
07-17-2015 01:59 PM
KwehCat
07-16-2015 04:48 PM
