Coupe Roof Top Trim strips removal/finish
Old 09-24-2011 | 03:24 PM
Larskeller's Avatar
Default Coupe Roof Top Trim strips removal/finish
On the coupe roof top, there is a trim strip about 5/8" wide that extends from the top of the windshield to the top of the rear hatch recess on each side about 2" from the upper body recess for the door header. My coupe's trim has flaked off, and requires refinishing, but only on one side. On the opposite side, the trim strip appears to have a vinyl covering of some type because there are tiny air bubbles that can be moved around with just your finger in a few spots. I checked the Crossfire Factory Tech's service manual and cannot find any mention of these trim strips anywhere in the body section or elsewhere in the entire manual. They appear to be plastic, or at least non metallic. It seems as though they would snap in/out, or flex and spring out. Can anyone provide information on these strips, materials, and/or removal and installation? Thanks.
Old 09-24-2011 | 03:31 PM
Default Re: Coupe Roof Top Trim strips removal/finish
If memory serves me, they are held down with 3M tape, removal is from the rear end, lift them up carefully. They can be purchased. They are metal.
MOLDING, Drip Rail
0YA00CY3AA 1 X 29 [Y3], Right
1 S 29 [Y3], Right
0YA00P41AA 1 P 29 [41], Right
1 X 29 [41], Right
1 S 29 [41], Right
0YA00P61AA 1 X 29 [61], Right
1 S 29 [61], Right
0YA00PDRAA 1 X 29 [DR], Right
1 S 29 [DR], Right
0YA00PRHAA 1 X 29 [RH], Right
1 S 29 [RH], Right
0YA00PS3AA 1 X 29 [S3], Right
1 S 29 [S3], Right
0YA01CBKAA 1 X 29 [BK], Left
1 S 29 [BK], Left
0YA01CY3AA 1 X 29 [Y3], Left
1 S 29 [Y3], Left
0YA00CBKAA 1 X 29 [BK], Right
1 S 29 [BK], Right
0YA01PDRAA 1 X 29 [DR], Left
0YA01P61AA 1 X 29 [61], Left
1 S 29 [61], Left
0YA01PRHAA 1 S 29 [RH], Left
1 S 29 [DR], Left
1 X 29 [RH], Left
0YA01PS3AA 1 X 29 [S3], Left
1 S 29 [S3], Left
0YA01P41AA 1 P 29 [41], Left
1 X 29 [41], Left
1 S 29 [41], Left
These are for an '05, and the numbers in brackets are the color codes for an '05.
The number one is the quantity, it will not format correctly for me.
mobilefitt
07-28-2015 03:45 PM
steps
07-27-2015 03:14 PM
mike28117
07-17-2015 01:59 PM
Josefigue
07-15-2015 04:51 PM
ardenian
07-09-2015 02:08 PM
Quick Reply: Coupe Roof Top Trim strips removal/finish
