Grill or not?
Grill or not?
Hey everyone, my name is benoit and im a college student from florida. I'm a new owner of a crossfire, 2005 white limited manual and i totally love it. One question i ask myself is if it would look good a grill on it. Its been a week i'm looking different choices and I would like to get feedbacks or thoughts on these 2 i found. CHRYLSER CROSSFIRE 04-08 3PC COMBO BILLET GRILLE GRILL - eBay (item 160531104536 end time Sep-08-11 17:00:16 PDT)
would the crome look good on the white?
or would the black look better
04-08 Chrysler Crossfire Black Stainless Mesh Grille | eBay
also I just saw that there vapor in my headlights. Is there a way to take it off?
hope to hear from you
thanks
benoit
thanks
benoit
Re: Grill or not?
Welcome to the forum!!! You will love this car. What part of FL are you in? I live in WP. I figure since half the colleges in FL are here in Orlando, that you might live here.
As far as which grill to go with, there are lots of photos of mods that other XF owners have done. I am including a link for you that should give you some really good ideas.
https://www.crossfireforum.org/forum...le-thread.html
on
Re: Grill or not?
The headlight issue is a long story. Do a search for "headlight repair and you'll find quite a bit of info.
As for the moisture (condensation) inside, there is a $25 kit you can buy from Chrysler that installs in 5 minutes that is for that same problem. here is the TSB for it. take that number to a Chrysler dealer and have him order the kit for you. And have them print out the instructions that go with it!
TSB: 13-Jan-05 - 08-002-05 - Lighting - Condensation in Headlamps
Good luck and Welcome!
Re: Grill or not?
I say go black, but I'm very anti-chrome and don't really like the billet grille. I'm planning on purchasing the black grille set for my bright silver roadster. It will be my venture into deciding on whether I want to get black wheels and do black on silver. If I don't like the black on silver I will just paint the grille silver.
Re: Grill or not?
[quote=benoitparadis]Hey everyone, my name is benoit and im a college student from florida. I'm a new owner of a crossfire, 2005 white limited manual and i totally love it. One question i ask myself is if it would look good a grill on it. Its been a week i'm looking different choices and I would like to get feedbacks or thoughts on these 2 i found. CHRYLSER CROSSFIRE 04-08 3PC COMBO BILLET GRILLE GRILL - eBay (item 160531104536 end time Sep-08-11 17:00:16 PDT)
thanks
benoit[/quote
Personally I have not seen a billet grille that looks good, that's my opinion anyway. They are just cheap looking as far as I am concerned, no style. The mesh grille I think is so so.
Many people who have put billet grilles on scratch their cars paint a lot, not good.
The best looking grilles are the modified OEM grilles, chrome trim or painted I think.
It's your car though so do what you want, but keep the OEM grille, you may change your mind.
As for the misted headlights, do you have day time running lights? If you have day time running lights I suspect you have a leaky headlight unit along the seam. Some are so bad that they look like a place to keep amphibians as they are so wet.
I have DTRL's and never saw moisture inside but I purchased the kit mentioned anyway. Does the moisture appear after washing the car or raining and does it go away at all?
thanks
benoit[/quote
Re: Grill or not?
It's not for everybody and I'm not a fan of them for at least my car. In fact I've not found a grill yet that I like better than the stock...though I have toyed with the idea of painting it the same color as the car. Good luck with whatever you do and just make sure it is what YOU want and not a popular vote.
Re: Grill or not?
on
1 Post
Re: Grill or not?
What I do for condensation in the headlights:
Obtain a vacuum cleaner (shop vac)
Get like 3 drinking straws (bendy kind is okay)
Shove the straws in the vacuum hose and tape the so they don't come out
Remove your "corner" light (eyebrow light, whatever. The light in the top corner of the headlight)
Stick the straw tipped vacuum hose into the hole where the corner light was.
Try and seal the hole as best you can with tape (doesn't have to make an airtight seal, but works better the more airtight it is)
Turn the vacuum on and let it suck until all of the condesation is gone.
Works for me.. i've done it about 4 times. Only problem is the water in my area is extremely hard, which leaves water spots on the inside. I'm planning on getting halos though, so i'll clean it when I put those in.
Hope this helps
-Eric
Hope this helps
-Eric
on
1 Post
Re: Grill or not?
Oh and here's my XF with the black mesh grille as well. Problem with them is they don't fit 100% out of the packaging. I had to bend a corner in (and I went for local pickup, so I know it wasn't damaged during shipping). And other guys say they have to mess with them to get them to fit. But I still love it!
One of the guys on the forum has a white XF with all of the trim pieces in black (door handles, strakes, grilles, etc.) and it looks amazing!
-Eric
-Eric
on
1 Post
Re: Grill or not?
Originally Posted by benoitparadis
thanks eric, and softball junkie, where did you get that sign? its sick, im thinking of buying the black grill and keep the regular if i change mind, thank you guys
I still have my OEM grille as well. Before I had the money for the black mesh grille, I used this colored adhesive tape stuff I bought at Pep Boys on my OEM grille. Covered up the silver and made it all black. I liked it for a while, and it's extremely cheap to do. I think the tape was like $7.
Good luck in whatever you decide!
-Eric
Location: sandhurst UK..home of the royal military academy
on
1 Post
Re: Grill or not?
on this side of the atlantic there arn`t many options for another style of grille and to import one from the US doubles the price with import duties and tax so i colour coded mine and added chrome strips where the silver ones were and must say am very pleased with the result...
Re: Grill or not?
thanks guys, i am originally from quebec canada, but i study in lakeland florida which is 45 min from orlando. I still hesitate if i should put a grill or not. It looks nice like this but black grill would put an agressive look. Decision is hard
https://www.crossfireforum.org/forum...23-2011-a.html
Re: Grill or not?
Hope this helps
-Eric
Hope this helps
-Eric
RED DOG
44
10-27-2020 09:00 PM
