Rear Brake lights on and dont shut off
Hello I am new to the forum, I need some assistance :
My rear tail lights and cruise control are not working properly, The taillights stay on the entire time the car is running, when i push the brake pedal the tail lights blink but remain on . I checked the fuse box, fuse is ok. Any ideas ? thanks.
Re: Rear Brake lights on and dont shut off
Originally Posted by Hipower
New the forum I have and 04 Crossfire, i need help, My rear tail lights and cruise control are not working properly, The taillights stay on the entire time the car is running, when i push the brake pedal the tail lights blink but remain on . I checked the fuse box, fuse is ok. Any ideas ? thanks.
Start on the simple stuff first.
on
went to check , a no go . i also checked fuse box no fuses blown.
Or possibly just a visual check to ensure it phsically engages by depressing the Pedal...???
on
I have yet to be in this area personally, but according to the Service Manual (page 5-53), you need to remove the Panel sitting right above the pedals.
You should see the Stop Lamp Connector, which is for the Stop Lamp Switch.
It's the connector or Switch that should be of interest...
If anyone has been here, I'm sure they'll chime in...
Roty135
17
10-11-2018 10:11 AM
axnguyen
07-21-2015 11:41 AM
