installed hid fogs, driver side won't turn on, hardware is fine
35w kit, passenger side works fine, driver side wont turn on. Tried swapping hardware, same results.
Led bulb and regular halogen bulb work fine on driver side. Tried swapping the stock harness for a new one and same results.
I'm out of ideas, andyone have any before I button everything up?
Re: installed hid fogs, driver side wont turn on, hardware is fine
Originally Posted by Sheldon
Could they be wrong if the other bulbs are working fine?
I hooked up the color coded wires as per the instructions, and it did not work on one side. I switched the wires on that side and it worked.
Yes, I had the same trouble.
So the wires that would normally plug into the stock bulb right? It wont blow anything up if its wrong will it? :P
