Help - installing halos, need tips on opening headlamp
I'm in the process of installing the ORACLE halo kit and am at the step of removing the headlamp lens cover. I have placed the assembly in the oven according to the instructions with no success. It seems that I would cause more damage to the assembly if I continue doing what I'm doing. Is there a better way to do this without damaging the headlight assembly?
on
Re: Help- installing halos, need tips on opening headlamp
According to others that have done this in the past, the best way on these lenses is to cut the lenses off with a dremel and then epoxy the lenses back on. The oven heating method does not seem to work on these.
Do a search for "angel eyes", and you will come up with information on how others have done it.
07-24-2015 07:57 PM
3spencer3
07-24-2015 01:08 PM
