painting inside of headlights. need ideas
Re: painting inside of headlights. need ideas
I am always partial to silver trim, it is all personal preference.
While you have it apart, you need to get a set of 120mm halo/demon eyes installed.
Holy ****, that looks awesome. Are you stilling running halogens for your hi, low, and fog lights? Did you switch those to HID's?
on
1 Post
You can NOT bake these lights apart the urethane that Valeo uses has a higher melting point then the light housing! If you look at james1549 gallery you can. See they cut the clear lens and then epoxied the parts back together. On mine I cut the top grove off of the housing ( leaving about two inches on the corners) and then cut the urethane, this way I have points to align the lens as well as a half inch around the light to re seal . Some people use epoxy , rtv silicone or butal tape .how ever I suggest using a good urethan like sika for example. Its what Valeo used originally. ( same stuff used to glue in windshields )
