lining up headlights
on
1 Post
on
Re: lining up headlights
The highs and the lows are opposite from each other. I can't remember which is which.
Loosen the spring clip
Rotate them while they are on. When you hit the "Sweet Spot". you'll know it!
Replace spring clip.
They don't get hot and it's only 12VDC. You won't get hurt.
If you have them on you can see the little dot shadow that should give you a good marker to go by. Check This Thread it may help you out.
