3M Restoration Kit, results and questions
Old 04-18-2011, 06:23 PM
Default Re: 3M Restoration Kit, results and questions
Originally Posted by 604Cash
I used 2000 grit wet sandpaper, then Optimum HyperCompound on a cutting pad w/ Porter Cable x 2 passes, then Optimum Compound on green compound pad w/P.C. x 1 pass, then Optimum Polish on white polishing pad x 1 pass. Sealed with liquid Meguiars NXT wax. Like new.
This is a great do-it-yourself technique. Thanks for sharing,
Old 05-14-2011, 09:25 AM
I used the 3M restoration kit on my headlight, spent 2 hours on it, and it's the same, probably worse if anything, i followed all the instructions to the letter from the 3M site, the outside of the light is very smooth compared to the other light (which I haven't done) but there's still something in the way when the light is switched on...
Do you guys think that this is probably inside?
The pics, i've attached are actually before I did it, but it's moreless the same after... apart from some of the scratches have gone a bit...
Old 05-14-2011, 12:49 PM
It is possible for the inside to be defective, but it is hard to tell by the pics. Are you sure the clear coating has all been sanded off? Again it is not clear, but it looks like the clear is still on the lens.
James
Old 05-14-2011, 01:54 PM
well i sanded loads, infact I used all of the pads that were intended for both lights on just one headlight
Old 05-14-2011, 01:59 PM
Did you sand to this level?
If it still looked like this, then it wasn't enough:
IGot2P
10-24-2023 02:56 AM
deerhunter
01-16-2021 10:56 AM
xfireohio
07-20-2020 12:03 AM
RedNeck
09-04-2015 09:54 PM
da pink
08-12-2015 05:20 PM
Quick Reply: 3M Restoration Kit, results and questions
