Clear Sidemarkers ?
  #101 (permalink)
Old 02-17-2010, 12:45 PM
Default Re: Clear Sidemarkers ?
Originally Posted by MikeR
Has anyone found any chromed RED 194 bulbs to use??
Has anyone had any luck finding these? I've have done all kind of internet searches and came up with zilch.
  #102 (permalink)
Old 02-17-2010, 12:57 PM
JHM2K's Avatar
Back in my Ranger days, we simply used red bulbs and hit 'em with a light coat of silver metallic paint. The light comes right through if the coat is thin enough...
I used red 194 bulbs in the interior of my Ranger's cabin... they lasted forever.
As cheap as the bulbs are, it's an inexpensive experiment.
  #103 (permalink)
Old 02-17-2010, 12:59 PM
MikeR's Avatar
Same for me Inferno.....
  #104 (permalink)
Old 02-17-2010, 01:08 PM
ZAHANMA's Avatar
Very very good point... this could be interesting. a quick experiement with different types of paint on the bulbs too...but then again that could get expensive...
whoever tries this, don't forget to tape off the bottom of the bulb...I'd hate to see the bulb come out beautifully and then not be able to use the bulb because of silver paint covering the connectors... hahaha..
cause lord knows that's what i would do in my rush to get it done haha.
  #105 (permalink)
Old 02-17-2010, 01:47 PM
Good idea. I already have a can of Rust-Oleum metallic brilliant metal finish spray paint.
  #106 (permalink)
Old 02-17-2010, 02:00 PM
JHM2K's Avatar
What we used to do was simply poke the bottom connector tip through a box or an old egg carton; the cardboard will hold the bulb perfectly upright and hide the contacts. Bulb is silver, contacts stay metal.
Inferno, that paint should be perfect. Clean the bulb with alcohol first, let dry, and let her rip!
  #107 (permalink)
Old 02-17-2010, 02:14 PM
bmorgan's Avatar
Great idea John. I look forward to hearing some results from this.
  #108 (permalink)
Old 02-17-2010, 05:10 PM
When I first put in my rear clear markers, I couldn't find red 168 or 194s. So I lightly coated a pair of clear ones with spray red high temp paint. After about an hour with them turned on at night, they began to smoke and burn. Took 'em out right away. Silver paint may be different. Those little bulbs get extremely hot after being on for just a short time, especially in a small confined area such as a marker housing.
James
  #109 (permalink)
Old 02-17-2010, 05:17 PM
try you local motorcycle catalog or store...I am going to wire in some motorcycle clears that turn red when activated....
  #110 (permalink)
Old 02-17-2010, 06:10 PM
JHM2K's Avatar
Definitely test them first, before you put them back in the housing.
When I used them on the Ranger, there was a lot more room in the housing. I also used high-temp paint...
  #111 (permalink)
Old 02-18-2010, 09:51 AM
sowardcustoms's Avatar
I have one more set if anyone's interested....
  #112 (permalink)
Old 02-18-2010, 12:44 PM
Steve - UK's Avatar
Im Looking for some red rear markers if anyone has a set tucked away
  #113 (permalink)
Old 02-18-2010, 08:53 PM
hcarter's Avatar
Hey guy's take a look at these i think they are coated pearl to look clear when off but turn red when on ,,,a little pricey but might be the bulb for rear markers
Polarg Visual Light Bulb > Wedge Type Bulb > Red Color
  #114 (permalink)
Old 02-19-2010, 11:20 AM
MikeR's Avatar
Interesting that it says the color is ion yellow when off and red when on...... has anyone ever seen these bulbs?
  #115 (permalink)
Old 02-20-2010, 06:16 PM
Mike....take a look at these..... www.jamstrait.com
  #116 (permalink)
Old 02-20-2010, 07:09 PM
bump......for those looking for lighting....
  #117 (permalink)
Old 02-20-2010, 08:11 PM
MikeR's Avatar
Thanks Doc... I dont want to have to use load resistors for these.... I will go check them out and see if they need them.... the website says 'no known requirement'...
  #118 (permalink)
Old 02-20-2010, 08:15 PM
hcarter's Avatar
Doc have you used these ? any light out indicator issues ? i like these i may go ahead and try them ..
thanks for the link
Howard
edit : just read where it makes no difference which way you put them in they will work if thats the case they may not need resistors ,,
  #119 (permalink)
Old 02-20-2010, 09:04 PM
thanks for the link
Howard
I thought they were worth a try...O'Reilly's had them.....but, no, I just don't know....lol
  #120 (permalink)
Old 02-21-2010, 07:35 PM
MikeR's Avatar
I went a got a set of these today to try them out.... they work fine..... ....but give a light out indicator
I also got some red 194 bulbs to try painting with silver or chrome paint to see if they will work.... I still need to pick up a can of high temp paint and spray them...
Quick Reply: Clear Sidemarkers ?
