low beam bulb spring and caps
Old 11-02-2009 | 02:01 PM
Erzer's Avatar
Default low beam bulb spring and caps
Does anyone have a spring for low beam bulbs? I also need a couple of caps for covering the bulbs.
If there is a simple way to get the spring out of the assembly area (can't see it anymore) then I won't need a spring.
Old 11-03-2009 | 04:41 PM
inot2old's Avatar
Default Re: low beam bulb spring and caps
I just did the same thing. Have you tried using a mirror to look for the spring, one thing that I tried, (but it didn't work for me) was to slide a refrigerator magnet, (the flat, flexible kind) down in the headlight to try & get the spring clip. Good luck, if you can't get it there was a guy who said he had an extra sping clip.
Old 11-03-2009 | 08:20 PM
Erzer's Avatar
I didn't think the clip was magnetic, but I may not have a strong enough magnetic tip on the screw driver. Either way, when I took the spring from the high beam to use as my low beam clip, I saw the other one. Now I just have to find something long enough to reach and grab it. This is going to be a challenge that's for sure.
Old 11-04-2009 | 06:46 PM
Erzer's Avatar
Success, I borrowed a telescoping magnetic pen and managed to fish it out via the high beam opening.
I went this route because when I was borrowing that clip for the low beam so I could drive to work without being hassled by the cops for a burnt out headlight I saw the clip out of finger reach. Plus this opening has more room to see what is going; not much, but enough. Thanks for the magnet idea!
Old 11-04-2009 | 08:35 PM
This thing is real handy, it has spring loaded gripping fingers, a magnet and this one has a light. You hope you never need it, but when you do its a life saver.
Amazon.com: 3-in-1 Flex-Shaft Retriever tool- Claw, LED Light & Magnet: Home Improvement
Old 11-06-2011 | 05:05 AM
joejones's Avatar
Does anyone know where I can get a replacement clip?
Old 11-06-2011 | 05:50 AM
contact maxcichon - he makes them.
Old 11-06-2011 | 07:23 AM
maxcichon's Avatar
And I think I still have 2 caps.
Old 11-06-2011 | 08:08 AM
Max springs into action again and saves the day.
Old 11-06-2011 | 03:20 PM
Larry Hitze's Avatar
I think that I have a couple of rubber caps too if needed, I'll check tomorrow because I'm at the Fire Station today.
Old 11-06-2011 | 05:07 PM
joejones's Avatar
I have the rubber caps. I need the metal spring that holds the bulb in.
Old 11-07-2011 | 08:46 AM
mp3wizard's Avatar
I also need 2 springs, if anyone has any spare/for sell?
Old 11-09-2011 | 02:24 AM
devilduck's Avatar
I could use 2 rubber caps- hint, don't let your kid work on your lights unsupervised, even if he has the nimble fingers! Thanks
Old 12-21-2012 | 04:30 PM
terry b's Avatar
bought a 2005 roadster. Changed a low beam bulb - clip was missing. I can sympathize as I fought these for years on a volvo.
Anyone know where I can get one? Of course I would pay. Its ridiculous that you have to buy a whole head light assembly.
Anyone know if SLK's used these? Maybe mercedes sells them.
I'll probably scour a few junk yards.
Cheers and merry christmas
Terry
Old 12-21-2012 | 05:00 PM
Terry
Try and contact Maxchicon on this forum he has in the past made some for others, I don't know if he charges or not. Merry Christmas
Old 12-21-2012 | 05:58 PM
maxcichon's Avatar
I sell them and have some made up.
PM me?
4drturbo
21
11-12-2018 05:50 PM
ritous1
09-26-2015 02:27 PM
ayebb
09-18-2015 04:35 PM
MickeyNasty
09-06-2015 09:29 PM
maxcichon
09-04-2015 01:50 PM
