Windscreen attached directly to roll bars
Just figured I'd share another way to attach the windscreen. Essentially flush mounted the screws into the lexan screen and through to the roll bar. Between the windscreen and the roll bar is a washer which came with a rubber washer to separate metal to plastic and to cut out all vibration noises. I am very happy with results...it looks stock IMHO.
on
Re: Windscreen attached directly to roll bars
I looks like it would work wonderfully.... I am sure better than my WindRestrictor. But......... Whew..... I don't know about drilling into the roll bars like that. I am just not feeling it. Maybe some screw head caps would help, but..... I don't think I could do that to my baby.
on
I don't own a Roadster, but I like that idea the best so far as vibration is concerned. Its only a car, it's not a living thing, you can drill holes in it. Those bars come up for sale quite often if they every have to be replaced.
James
James
Not an engineer so those of you who are can chime in. I would think that drilling into the roll bar would potentially violate the integrity of the material and thus should you need it, it might collapse easier. Especially when you start drilling multiple holes as this screen seems to want.
I have the windscreen you mount using the umbrella hooks and I ended up putting some foam pieces on the back between the screen and car to eliminate the vibrations I had.
I don't know that I would go as far as drilling holes in the roll bars. I think a color matched zip tie looks better than a screw... plus if you get tired of it... no screw holes to live with.
on
Originally Posted by konja
Somehow the experiance of a roadster is th wind blowing through your hair, can't immagine driving with the top down and windscreen and windows up. Might consider a good conditioner for your hair to keep out the knots.
on
Originally Posted by itsky
Well, in the winter time when you have a nice clear day and the temperature is up to 45-50, you do appreciate the windscreen (as well as the heater ).
cjw
10-26-2015 10:26 PM
2005 Ragtop
10-03-2015 03:01 PM
