My Experience with the 3M Headlight Restoration Kit
Old 08-07-2012, 06:32 PM
xfireon20z's Avatar
Default Re: My Experience with the 3M Headlight Restoration Kit
Originally Posted by FUBU
You like the small white dots in the engine bay? I forgot to put a blanket over it aswell...
haha i did the 3M headlight restore about 2 weeks ago and when i got to the rubbing compound part i forgot to mask off the hood and fenders cause by the time i got done it looked like i could play connect the dots on my car cause of how the drill threw the excess wax off the pad
Old 08-07-2012, 09:51 PM
It wasn't the polishing compound that spattered; it was from the wet foam 3rd-stage fine sanding disc. No worries for me, though...... the headlights were the first step in my mid-summer detailing which always includes every bit of the engine bay to show-room lustre. For me, that task is never a chore. The finished lenses look absolutely brilliant.....
Old 08-08-2012, 06:18 PM
ImportLabSRT's Avatar
Wow, I am going to have to do this. Should be easy with my headlight assembly on my tool box.
Old 08-08-2012, 06:45 PM
Not really, unless you have a partner to hold it in place. There is no 'safe' way to secure it without the chance of breaking one or both lower mounting tabs ( they are VERY fragile ).
It is actually easier to leave them in the car and mask off around them.
Old 08-08-2012, 07:03 PM
They are already off the car... I could put them back in and do this if I feel up to it.
Old 08-08-2012, 07:53 PM
rayth's Avatar
If anyone else wants to do this, I have the kit unused that I can sell... I bought it but then just had the body shop clean up my headlights when they were painting stuff for me...
Old 08-04-2022, 11:28 PM
Administrator / Senior Member
My experience was very good !!
I used the kit to restore the headlights on my 2010 Ford Edge
The results were very impressive
Old 08-05-2022, 09:36 AM
waldig's Avatar
I have begun to use McGuires UV spray for headlights, seems that they suggest annual applications to protect the naked lens after polishing. Woody
Old 08-05-2022, 10:04 AM
I read mixed reviews about that product....
**Some said it's difficult to apply an even coating
because it is a spray on application.
**Some said it became cloudy after a short time and they ended up restoring the lights again to remove the product
I value your feedback because I certainly do want to apply a UV protection right away
Also have you had success with any other UV protection products that can be applied with a micro fiber towel ??
Old 08-05-2022, 10:22 AM
I use ‘Meguiars Headlight Protectant’ and apply it with a microfibre towel, but I have never had to refinish my lenses. It does no harm anyway.
Old 08-08-2022, 06:56 PM
I figure it is far easier to keep the headlights polished on a regular basis after a restore using the 3M kit than applying any new type of spray-on sealant/protectant on top after a restore that could just create more problems down the road. I've read the reviews of various after-market spray-on and let-dry protectants to use after a restoration and there are quite a few horror stories. I just hit them again every 6 months or so with a basic light headlight restorer rubbing compound that I can do with an old piece of towel by hand (or even use the old foam pad from the first kit I bought and kept and cleaned afterward that I can put into my drill again). Worst case, I'll just buy another full restoration kit again down the road if/when I need it.
Old 08-08-2022, 07:48 PM
I'm going to apply this for the UV protection
Another 3M product
northern 6
Detail Shop
04-22-2016 08:41 AM
joejet
03-06-2012 05:26 PM
billwyrsch
07-17-2010 10:16 AM
HowardJ
12-08-2009 04:25 PM
Stevefromtyler
11-28-2009 09:58 AM
Quick Reply: My Experience with the 3M Headlight Restoration Kit
