Tail light Overlay (Black out) Question/Help!!!
Hey guys I have the tail lights blacked out with an ebay overlay vinyl which looks oretty nice for what I
paid(although its a 2 man job) although I wanted to have the reverse and signal lights that are originaly
white, still in white, I though at first about doing the same shape as the circle and the triangle looking shape
but it is way too hard, does anyone know if the sell black vinyl with those areas already pre-cut???
Like this Civic Si has, but with our Crossfires is what I want of course...
[IMG]file:///C:/DOCUME%7E1/GABE/LOCALS%7E1/Temp/moz-screenshot.jpg[/IMG][IMG]file:///C:/DOCUME%7E1/GABE/LOCALS%7E1/Temp/moz-screenshot-1.jpg[/IMG]
on
1 Post
Re: Tail light Overlay(Black out) Question/Help!!!
I haven't seen any precut vinyls that have thhe reverse lights cut out already. This is mainly because it is one smooth surface where as most vinyls that have certain lights cut out are because they are on different levels and not a smooth surface.
Can you send a link to the ebay item you purchased.
The place I am taking my car to do window tint says they will only paint the tail lights and that is not what I want because it becomes VERY difficult to remove...pretty much the only way to remove is to change the tail lights which is very expensive...thus I want to go with vinyl.
I tried the spray first, its is a piece of crap man, its not hard to remove though, some nail polish remover
would do the trick(I just did it to my front side markers,but I would never do it to my tail lights), mainly
because it didn't look right to me so I went with these(link below) and it looks beautiful. The place were I
got my tint wanted to charge me $75 to install them, the hell with that, I did it myself with my friend(I
must WARN you, it is a TWO person job) and the materials are easy, a hair drier, water with soap, and a
little patience is all that is needed...although I realy wanted to keep the white spots on the tail light still
white...
CHRYSLER CROSSFIRE SMOKED TAIL LIGHT COVERS 04-07:eBay Motors (item 270445314583 end time Sep-19-09 11:50:13 PDT)
I'm not going to lie, I have painted my tail lights black as well. What you could try to do is that when you have painted them (if you want to again) and then when the paint has dried to the touch and can be handled in anyway, tape off the tail lights or cover them, and use the nail polish like you said and clean off just the reverse circles... I know that it may seem like a corny process, but that's what I would do.
white...
white...
Re: Tail light Overlay (Black out) Question/Help!!!
Yea, but your doing it once, its not like its a weekly thing man, but it takes patience if you mess up with the
pray and try to take it out, I did it until I got it right with my front side markers(I hate that goofy yellow), it
took me some time, but it gets the job done...patience is the key word...just get the vinyl its better for the
"health" of the car and its super easy to remove if you sell the car or get a fresh one on again...I just wish
there was a way to keep the white part of the tail lights the same without going through the trouble of
making the holes yourself, like a pre-cut vinyl for that two spots you know?
What if you put the tint on then take a razor and cut out the white lights. If you cant see it through the tint have someone else sit in the car and put it in reverse and hold the brake and then just put the flashers on. I think that would be the easiest. Just dont push hard.
Originally Posted by airborne82nddiv2003
I had my tail lights blacked out a few weeks ago and I couldn't be more satisfied with the results! I had the reverse lights and turn sigs taped off before the paint job, and then removed for the clear coat.
Originally Posted by FP
I have to wonder; if you get rear-ended while having these, will you be found to be the culprit? I was thinking about Debra Walker's accident. If she had the tail light darken, would she'd be at fault?
on
So you apply a clear coat after to make it shinny??? That aint a bad idea, completely forgot about the clear
coat, if that's the what I am thinking of....
The clear coat was applied to seal the paint and of course give it that glossy appearance and reflection, it should be treated as the rest of the vehicles paint. I had the side markers and 3rd brake light done as well. Included are a few pics from the process..
Thats awesome, I am going to try that once that vinyl goes to crap, its holding up so far, and maybe thats
why I have such negative feeling s about the spray, I was not only applying it from the outside, but no clear
coat...the white car looks nice, thanks for the pics. man
chrisIowa
07-29-2015 03:50 PM
KwehCat
07-16-2015 04:48 PM
cx24724
07-12-2015 11:57 AM
