Mesh side coves
Re: Mesh side coves
Originally Posted by Voyager
he may have scammed people here but dans ebay score isnt bad. he has only had one negative response. ive bought from much worse.
Re: Mesh side coves
Originally Posted by DICKBEE7631
Here are a couple of pictures taken 8/15/09. I use a 14MP SLR Pro Camera with Nikon Macro 60mm lens. The images I am posting are small JPGs to make it easier and quicker. If anyone wishes to see a magnified portion of any image, let me know I can create a closeup of any image I've taken.
I am convinced these grilles are solid stainless steel -- by the feel, the texture, the weight, the strength. One image shows a black plastic "pad" that will be installed behind the grille. I havent started install process as I need to get some supplies, namely double-sided adhesive tape to re-mount the silver strakes. I will photo the install process once I start.
Re: Mesh side coves
What are you going to do about the 6 holes in each fender that will be exposed?
I expect to "refill" the 6 holes by reattaching the strakes; the other two will be covered by the new grille.
RAB
Re: Mesh side coves
I see now what you mean, and good luck, truly....
I just put on some custom strakes myself and now that I know what you are trying to do, I think it will not only be a major pain in the ***, but the stainless look and the painted silver are never going to look right next to each other. Just my 0.02 keep us updated....
Re: Mesh side coves
RED DOG
44
10-27-2020 09:00 PM
2005 Ragtop
10-03-2015 03:01 PM
