Painted Calipers
on
1 Post
Re: Painted Calipers
Originally Posted by FP
Anyone have step by step instruction on removing the calipers? Everyone tells me it's easy, and while I've done my share of drum brakes, I've never tried the disc brakes.
Thanks, so no need to remove the calipers?
High Perf Caliper Paint Kit
Originally Posted by ///SilverSaphRT6
What did you use to prep caliper? I like that blue.
<--- Huge Horsepower
Brush on paint is good if you use the two part-epoxy type of caliper paint and take your time.
But for a really solid paint job, I removed the calipers, cleaned, sanded and masked them. Then painted with High Heat Cermaic paint (up to 1,200*) - but I also was installing Steel-braided brake lines and new fluid at the same time so it made sense to remove them.
on
1 Post
try the g2 products. its a 2 part epoxy that will do all 4 calipers. around 37$ shipped
heres the link for the caliper removal. its very detailed. the website also shows the rear removal SLK32 Brakes
i used the red on mine but g2 has a wide color selection
http://www.caliperpaints.com/
i did the same as brianbrave new pads lines fluid so it was easy to do it while removed. CAUTION! the clipers are side specific. if you mix the carriers you can reverse them but never get them to bleed. bleeder on top ensures proper side fitment. i know this cause i did it!! once you mix the paint you have a limited time to use it . once it hardens its scrap
on
Ive always had good luck by painting them while on. First clean them good with brake cleaner. apply bbq black hi temp paint as a primer. Then apply hi heat engine paint over the primer. To apply the spray paint, spray it into the cap or a cup until you have enough to brush on. small foam brushes and q-tips will get it all. I only do the parts of the caliper that show.
FP - I did mine myself on the car. Jacked it up, pulled the tires, cleaned it, taped it off, scrubbed the back to the wheels to get them clean, put the tire back on ..... rinse & repeat 3 times.
I think it took me about 1.5 hrs to do the whole car. I got caliper paint at the local auto parts store. They had lots of colors, but what other choice did I really have but red on a yellow car??
If I can do it .... you can do it!!
on
