Headlights look foggy (dirty)
Re: Headlights look foggy (dirty)
Originally Posted by rodimus
QUESTION-
I recently aquired a SRT6, a the headlights seem dirty or foggy on top, is this a common problem??
Should I bring this to the dealer attention?
THANKS IN ADVANCE!!
THANKS IN ADVANCE!!
Be sure and try our search feature in the future. It's a great tool. Try this post:
https://www.crossfireforum.org/forum...azy+headlights
Good Luck, let us know how you make out.
Originally Posted by chuck65
First you have to determine if your headlights have moisture inside or if the outside is hazy and in need of polishing. I used 3M Plastic Polish on mine and it did a great job.
Thanks for the tip. Just getting used to the endless information on this forum, it's amazing!!
I would I tell if it's on the inside?? I'm not to auto savvy so bare with me if that is a dumb question. That thread you directed to me to is great. If I can't clean it off, I guess it's back to the dealer I go.
THANKS AGAIN!!
THANKS AGAIN!!
THANKS AGAIN!!
I think i have a combo of inside and outside. I would say the easiest way for me to tell was to just wipe my finger across the haze. If it fades and comes back right away its on the outside, if not it's either reallllly caked on or on the inside. The haze has an almost purple-blue color also.
www.CustomCrossfire.com
Originally Posted by kurtisberry
If it is on the outside and still under warranty, the dealer should replace the headlights. Had mine replaced with two weeks left on the warranty for free. The TBS only deals with water moisture on the inside.
They did the TSB and it did nothing.... They just replaced the headlights, and they look great.
Are these a new version, will they have the same problem??
Funny this thread came back today. I just did my headlights with the Meguiar's PlastX. I bought it at WalMart for about 5 bucks. I spent about 10 minutes on each headlight applying the PlastX using a wax applicator. It works well for removing the haze at the top of the lights, but understandably doesn't do much for the small rock chips and deeper scratches in the lens. Overall I'm happy with the results! I'll probably do this each time I wax my car (which I also did today).
Check out my thread if you're looking for perfection:
https://www.crossfireforum.org/forum...ad.php?t=26589
I wish I had documented my recent experience with this...But there is a product made by Crystal view chemicals inc. go to: myheadlight.com I have an 05 and dealer refused to replace mine. So I procrastinated. My lenses were actually pitted in some spots with a yellow sun damage.
I bought this little kit and I was shocked at the results (15 bucks) I ahd ordered new lenses and cancelled.
If nothing else save those old lenses for experimental product testing.
when first got my car i complained and the dealer went in and it looked like they took a wire brush to it or something which got the fogy out but just scratched it and now a year later its worse then it originally was. i am going to get this headlight stuff that a friend that works at advanced auto told me to grab and it has a lifetime guarantee.
