HID Headlight Replacement Instructions
Old 05-20-2010, 11:51 AM
Default Re: HID Headlight Replacement Instructions
Just bought the new bulbs 8000K but how did you remove the head light assembly. I took the top two screws out and sill can't get the assembly out. Th drivers side I was able to remove and replace in place, but I can't get the other side with the overflow tank in the way. And advice would be appreciated.
Old 05-20-2010, 12:00 PM
SRT6 Gang Member's Avatar
THREE 6S
(8) screws total, (4) per headlight assembly, (2) on top and (2) on bottom, remove the bumper to access bottom screws and out they will come.
Old 05-20-2010, 12:35 PM
Wow ... anyway to do this without having to remove the bumper?
Old 05-20-2010, 12:52 PM
THREE 6S
It’s a sticky in this forum.
HID Install Lows and Fogs with Pictures
Provided by maxcichon
Old 05-20-2010, 02:20 PM
Infinite's Avatar
I put 6000k in mine, it took me, oh, an hour or so, to do highs and lows as well as pulling the bumper off
Old 05-21-2010, 12:31 PM
Thanks for the instructions, but one question ...... the radiator tank ..... it implies that you remove the ring on the bottom of the tank by pulling it off. Is this correct? I can feel the ring but no slit or tab. Or is it that the tank has to be pulled to one side or the other to release? HELP
Old 05-21-2010, 12:54 PM
hcarter's Avatar
Remove nuts from studs and pull straight up on tank,,,,little tough but it will come out .
Old 05-21-2010, 03:54 PM
Originally Posted by Nexxus
Sorry for the delay. I want to put full instructions up for the replacement headlight system. I am planning on re-doing the headlight installation in the next few weeks as I found a better way to do it.
Watch for my posts with full pictures and instructions soon!
Two years later this thread rises from the dead, amazing. I wonder when the promised pictures and instructions will appear.
This mod has been described better by maxichon which warranted its elevation to a sticky.
PNA
11-12-2020 04:44 PM
maxcichon
07-08-2016 08:28 AM
Charles Moore
08-01-2015 02:35 PM
Charles Moore
08-01-2015 02:33 PM
LINO C
07-31-2015 10:03 PM
Quick Reply: HID Headlight Replacement Instructions
