APS Mesh Grille...Special Price for Forum Members
Re: APS Mesh Grille...Special Price for Forum Members
[quote=SRT SIX]No problems with fitment. Installation is quite easy using the existing mounting points. I will get exact warranty info and post.]
I have one of your lower units but have had little time to install it. I took a look today at the directions and I see it affixes to the original plastic mesh grill. Can you elaborate please on how that original is removed? I stuck a long flat blade screwdriver into the hole at the outer end of one unit and I dont seem to be able to find whatever device is present there that I have to unattach. Do you have any sketches, details, suggestions on removing the factory mesh grill units? Any help would be appreciated. Thanks...
Did you get this off eBay from Grille4U? Someone else?
Check your owners manual. It shows how to remove the stock lower grille by inserting the "multi-tool" or screwdriver in the rectangular slot at the outside end of the grille and just pry out. It comes out easily as it is only held in place by pressure tabs.
Hope this helps...Now as to mounting the new grille over the original, good luck, if you got it from others. The factory instructions are...how do they say, uhmm...WRONG! My grilles ship with correct instructions.
[quote=DICKBEE7631]
[quote=DICKBEE7631]
Sorry for all the confusion. As stated my supplier greatly underestimated the demand for the grilles and as a result did not initially bring enough in. I was only able to get 3 sets for immediate shipment. The 3 individuals were the first to order and have already paid. I do not like to bill in advance of knowing the product is available. If you did not get an invoice via paypal, you will be in the next shipment.
I am checking first thing monday on the validity of the info I received Friday about another shipment coming in this week by air. There will be a premium of $15 per grille. I am negotiating that now. If it winds up being $15 per set, I will eat the $15 and attempt to get the grilles this week. If that is the case, I will be sending out paypal invoices immediately. When you pay the invoice PLEASE include your forum name and phone number. I will ship these as soon as possible.
Thanks for your patience and patronage,
Karl
Karl
Originally Posted by tylerxfire
i too am wondering if i am part of the first shipment or whats going on
It is a non-negotiable $30 per set for the next group by air. That is a no go! The next container load is suppossed to be here in 2-3 weeks.
Make sure I have your email and phone number. I will notify you all as soon as I get word on delivery.
Karl
Karl
[quote=SRT SIX]Did you get this off eBay from Grille4U? Someone else?
Hope this helps...Now as to mounting the new grille over the original, good luck, if you got it from others. The factory instructions are...how do they say, uhmm...WRONG! My grilles ship with correct instructions.]
I guess my manual is missing that page...I went through it page by page; no mention of the lower grille at all, unless I some how missed it. Same with the two-volume service manual, that shows them but doesnt say anything about them.
I bought it from grille4u---the instructions supplied have illustrations that are barely legible. The directions, otherwise, seem straight forward. I'll let you know if I have any other problems.
OK...I double-checked and indeed, I bought mine from Grille4u via eBay. With your added notes here, I figured out how the original lower grilles come out...no problem. However, I'm a bit baffled by the parts supplied with the grilles. The grilles have internally threaded studs mounted at both ends. Yet, with the grilles came nuts -- not bolts to thread into those studs -- along with some spacer pieces. I just happened to have two small bolts that fit the studs so got one unit mounted and it looks GREAT! Took 5 minutes. Now I have to locate two more bolts for the other side. How was I to use the lock nuts, the two large black plastic snap plugs?
I think I made an invalid assumption that you were grille4u...reviewing your postings I suspect that my assumption was wrong. I apologize for my confusion. Regardless of who provided my grille, and I think it was made by the same fabricator as yours, they are nice units. I presume your kits have the appropriate parts for installation.
Both Grille4U and my grilles are the same. They are made by APS. I am certain G4U is a subsidiary of APS. APS only sells wholesale so they are using the Grille4U name to sell on eBay.
As I mentioned the grilles from me come with the correct hardware and instructions. This is because I also got their instructions and parts and discovered they were wrong. As a result my grilles ship with the corrected instructions and parts.
Glad I was able to help somewhat.
[quote=DICKBEE7631]
[quote=DICKBEE7631]
I wasn't aware that there is an option of wide or thin chrome strips, are you speaking of the chrome strip that surrounds the outer edge of the grille, or are you talking about the center spline? Either way I would also like to have both so I can decide which I like better.
on
1 Post
It is the center spine. All I did was cut to length some chrome body side molding. I should have enough to cover those that want them. If not I will let you all know.
