Replacing rear-side marker bulbs
Saw Andrew's sticky about the part #s thanks for the info Andrew!
My right rear light is out so before attempting to replace I had a few questions for peeps who may have performed this already:
- Can I just pull the bulb & wiring assembly through the rubber seal through the panel in the trunk area? I found where it runs to but I didn't want to just 'yank it' if there was any kind of damage that could be done to the housing or assembly, any tips would be appreciated.
- Where is the best place to get a replacement? Can I get it through a Murray's or Autozone or do I have to go through the dealer?
- If this turns out to be a wiring harness issue, is that something that can be done relatively easily by a diy or am I better off taking it to the dealer?
Re: Replacing rear-side marker bulbs
NM...it worked 'almost' like it said in the manual...just using a minimal amount of elbow grease pushing towards the rear of the car and it popped right out.
Has anyone else had alot of their bulbs fail? There are alot of separate lights on this car and I've had to replace 3 of them. '04 coupe with 42k miles that stays garaged in winter. Not a big deal but it's not something I'm used to...my '98 Wrangler has 120k on it and I've only ever replaced one headlight...once!
I was concerned it may be an wiring harness issue because I could actually 'Fonzie' each light that went out (with a light rap on the light housing) and they would go back on for a while before they eventually failed. The bulbs were definitely burnt out when I replaced them...weird.
Me too , I am "constantly" replacing bulbs....3out 0f 4 sidemarker bulbs were ut . The front ones were easy after a little exploring . Have'nt yet figured out how to get the back oes out . Looks like a different method for the back ones. Any help?
I have not replaced any other bulbs.
Sussudio (10-07-2021)
REAR MARKER LAMP
1. Disconnect the negative battery cable.
2. Insert a trim stick (2) at the front edge of the rear marker
lamp lens (1), gently depress rearward and lift out from the
fascia.
3. Rotate the socket counterclockwise and remove the rear
marker lamp bulb from the socket.
The fronts are identically removed but they are moved forward.
MFDXF (05-28-2022)
xfClifford
27
11-10-2015 10:08 PM
