Replacing Low Beam...
on
Re: Replacing Low Beam...
You don't really need a link. The procedure is pretty obvious:
- Pop the rubber dust cap off the back of the lamp housing. (Low beams are on the outside).
- Disconnect the wiring harness from the lamp by grabbing the connector and pulling straight back.
- Un-latch the bulb retainer clip. (use a small mirror to look in the housing to see how it works if you can't figure it out by feel).
- Remove the bulb.
the little clip is a little tricky to remove. the mirror works great to see, you might need a screwdriver to push the clip over, it goes back together a lot easier than it come apart, the right side high beam is a real pain in the a@@. i just replaced both the high and low with HALO xenon plasma blue 12v100w/170w, they are a cheap but cool upgrade that require no wiring mods $6.00 a pair on ebay... good luck.
on
If you want REALLY bright light, save your pennies and get the McCulloch HID kit. It's worth every penny you'll spend.
hi, i'm a little confused on the bulbs, are they h7? 12v100w>170w, i noticed in other threads, people have gotten the h7, and have had no probs. i sure don't want to fry anything out. any advice on this would be appreciated. the bulbs are actually halogen, is that incandescent? i am lighting spec challenged.
don't use higher wattage bulbs ... these headlights are too expensive to replace when damaged by heat ... plus do the math and it makes no sense ... buying 100 watt bulbs that you will replace every 6 months at $20 bucks a pack ... or purchase a cheap HID kit on ebay for $130 that will last 2 - 3 years, draw 35 watts, generate less heat, output more light ...
i've played with 100 watt bulbs from all different brands a few years back on my neon and had to rewire the harness with heavier gauge wire and 40 amp relays to make it safe ... but even then the light output was not as good as a cheap HID kit and the cost of wires/relays/sockets added up ... HID systems cost over $500 back then so it made sense but not anymore ...
on
Your wiring harness was designed to operate with 55w lamps. There's some safety margin built in to the design so you can go up a little (maybe 85w, max) but a 100w lamp (almost 200% of the design spec!) is definitely outside the margin of safety.
If you're looking for max light output, HID is the way to go. Look for a 4,700k - 5,000k kit. That color temp is closest to natural sunlight and will give you the best illumination. I personally have a 6,000k kit because I like the slightly blue/purple hue at the edges of the of the beam pattern.
As far as HID kits go, a decent one will run you about $300 on Ebay and will not cause the "bulb out" sensors to get mad at you. Installation is relatively easy as well. I posted a detailed "lessons learned" on this forum a couple of months ago. You can read it here if you're interested.
I think a lot of us have the McCulloch kits. I love my 6,000K. I would personally go with the 5,000K kit. Not to say the 6,000K is that bad but I think the blue/purple hue on the edge of the pattern is a little too blue. It's a great upgrade, not only for looks, but for safety
I got mine for $280 on eBay and the light output is awesome compared to stock and you should never have to worry about blown bulbs, plus once you drive with HIDs you won't go back to normal halogens.
thank for all the advice,the 100w's are in the garbage and im definitely getting the hid upgrade!!! i was looking and i think i'm going for the 8,000 for the low beams, i like the blueness of them, so do i need 2 kits for the high and low or can you jump both sets of lights from one hid kit? also maybe going for 6,000 for the highs, will that be a whole new setup?
on
Just be aware that 8000k lights will look wicked cool but their light output will be less. As the color temperature goes up, the light output goes down. Stick to something that's close to natural sunlight: 4,700k - 6,000k for great visibility at night. Buy a set of 8,000k bulbs for the fog lights instead.
Also, I wouldn't recommend getting HID for the high beams. HID lamps take about a minute to "warm up" and come to full brightness so they're not very good for the short, intermittent use that the high beams normally get. Grab a set of PIAA Ultra White or Sylvania SilverStar lamps instead. They will look yellowish compared to the HID low beams, but not as yellow as the stock halogen.
5k range will be the best light output and also brightest as mentioned in the posts above ... this has the added bonus of the "color band" created by the projector being much more visible ... projector headlamps create a bright colorful band of light where they cutoff on the area they are lighting ... this is highly desirable in the light guru circles, where as the colorful 8,000/10,000/12,000k bulbs are largely seen as "for show only" ...
but get what you like we all like a little show with our go.
i just got finished installing my 8k hid kit. it took about 2 hrs, you know those little retaining clips are a pain in the ***! but i was very happy with the mounting bolts that were in the engine compartment, that made for a very clean and tight set up. thanks for all the advice on the hid's!!!
