Headlight Assembly/Xenon Warranty Question
This is kind of a two part questions. One is, do my xenon lights void m warranty? no for the other question, I noticed recently that my passenger side headlight assembly is starting to cultivate water/dew inside and wanted to take it in to get a new one. My questioins is, if I take it in will the dealer try and tell me that the water is because I didnt install my lights correctly or some B.S. relkated to that, or does that have nothing to do with my assembly?
on
on
1 Post
Re: Headlight Assembly/Xenon Warranty Question
Its a TSB for the headlight they wont replace them unless the quick fix doesn't work. Now when you say xenons do are we talking HIDs where you had to cut a small hole in the rubber seal to run the wires through?? or just swapped out the bulbs for brighter xenons?
xfireohio
07-20-2020 12:03 AM
Adrian_X
11-09-2017 08:49 AM
