valve cover leak
Re: valve cover leak
( Go ahead and replace ALL the screws however, and use proper torque )
from dedwards0323 :
During re-assembly of breather cover I checked for valve cover bolt torque setting and found 10 N-m (7-8 Ft-lbs) on the service manual disc I've got. After I tightened the 2 bolts that pass thru the breather cover, I checked the remaining valve cover bolts. Found all of them less than 10 N-m. Re-tightened these bolts also. Then I tightened the 2 small hex head machine screws in the breather cover to 5-6 N-m (slightly over snug).
tritongreen
09-18-2015 08:32 AM
