AC/Coolant/Radiator Combo HELP
Hey Guys,
My radiator had a leak. I ended up getting a new radiator, installed it as per spec and it seems to be working fine. The car runs, doesn't overheat (the temp gauge shows just a hair above center). Ran the car on day 2 and noticed the radiator light. I checked for coolant, and the coolant is full. I researched hundreds of pages of possible problems but I can't seem to narrow it down.
I turned on the ac and noticed the fan was running. But then I noticed the ac not cooling. Pulled over, checked the fan again and it turns out the fan is not running at all even with the ac on. Does this mean something that tells the fan when to run is defective?
Please help.
Thank You,
FJP
Please help.
Thank You,
FJP
Re: AC/Coolant/Radiator Combo HELP
Hey Guys,
Please help.
Thank You,
FJP
Please help.
Thank You,
FJP
So right after the install. The first day. I did notice the fan was running under normal conditions. Example Run ac, fan operates. Car heats, fan operates.
However the fan as of right now was not running even while the ac was on.
I did check the connection. Plugged in.
No radiator fan = no AC.
UPDATE: The fan turns on sometimes and sometimes it does not. When the car was idling for 10 mins the temperature jumped to full hot. But because the fan kicks in once in a while I'm confused if its something other than the fan itself.
Someone please help!
Cheers!
Cheers!
Noted! Thank You! The car is parked back into the garage, and I just ordered a new fan. Hoping to install that as soon as it arrives and see if I have any success. Definitely guess work since I haven't isolated the problem. But I think its a safe bet, seeing as my fan makes squeaking noises while running at low speeds anyway.
I am not familiar with the fan controller, but I would start diagnosing there. See if it is getting a signal to turn fan on. There should be information somewhere on this forum or in the manual to explain the works. When the fan is not turning but supposed to be, can you spin it to start?
James
James
To cool the car the fan does not run all the time. It will run more when the car is stationary. When the car moves the rad is cooled by the air going through the core so no fan is required a lot of the time.
The needle climbed to max... top of the spectrum.. H as soon as the car was parked and idling for 10 mins after driving to the store and back. Which means the fan was running earlier but decided at some point to stop running, even though it should have been.
As I said in my previous post the movement of air through the rad as you drive is often enough to dissipate the heat from the engine. When you are stationary there is little heat lost through the radiator.
Thanks!
what exactly is supposed to happen? The fan spins like it’s going to take off? It already does that. I know it spins. It just spins at its own discretion.
Where do I locate the temp sensor? And is the module the little box next to the fan where the power for the fan comes from?
Thanks!
Thank you. So after some thought. I'm guessing it's probably the module. Since the coolant temp sensor seems to be correctly determining that the temps. It tells me when its cool and it tells me when its too hot. I am guessing it is the modules job to take that temperature info and operate the fan with based on it. ?!?!
