Limp Mode
Limp Mode
Hello Everyone
Well I had been enjoying my car for a minute .I went out yesterday and replaced the trans connector bushing.Due to a bad leak.After completing job and adding fluid.Car clunks hard into gear and fails to shift in either mode...Check engine light on.Do I need to Unhook battery and reconnect to re program?Open to advise,and thanks in advance...
Re: Limp Mode
Just wanted you to have two people tell you the same thing. Do not drive till you get the right amount of trans fluid back in it. Rob (Needswings) also had great advice. Your transmission doesn't have a dipstick. You can purchase one at a local Mercedes dealer or from Rob@Needswings.com. Also talk a look at the "how to" articles under the technical section of the forum.
Re: Limp Mode
Using the dip stick this post shows how high the oil level should be up the dip stick when it has bottomed out in the pan. CLICK
Use the correct oil, not just any transmission oil.
Re: Limp Mode
We do not know how much you lost.
Re: Limp Mode
When you reattached the connector did it go on smoothly or did ya haveta "coax" it on?
If the latter you may have done damage to the internal connector.
Checkout this post.
https://www.crossfireforum.org/forum...tml#post452377
Been there.
Checkout this post.
Been there.
Re: Limp Mode
Checkout this post.
Been there.
Checkout this post.
Been there.
