Limp Mode
Old 02-29-2016 | 06:32 PM
tighed1's Avatar
Default Re: Limp Mode
If it's the connector on the conductor plate located under the valve body then the repair is to replace the conductor plate.
Old 02-29-2016 | 06:39 PM
Steve Jr's Avatar
Originally Posted by foxxfire7
Inside opening for connector plug on trans,so I will need to replace plate?
The pin didn't disappear, if it broke off, is it ,in the connector, or the transmission,or on the ground?
Old 02-29-2016 | 06:59 PM
foxxfire7's Avatar
Originally Posted by tighed1
From the outside of the connector or are you looking inside the trans?
Pic?
inside transmission,
Old 02-29-2016 | 07:00 PM
foxxfire7's Avatar
I looked for it ,but clearly see an opening where a small hole is by other pin inside tranny.
Old 02-29-2016 | 11:53 PM
That is pin #5 and it is not there at all, it is a blank hole with no pin.
The number is not identified but it is next to the pin identified as #6.
You are OK like that.
Old 03-01-2016 | 08:31 AM
foxxfire7's Avatar
Thanks 180..I will get a picture of it later.Unable to see clearly inside connector port.Due to space.But can hold camera up there and use it like a telescope.Also I've been getting a clicking sound under hood in passager side fuse compartment.A flat silver box.
Old 03-01-2016 | 10:43 AM
foxxfire7's Avatar
Check engine light on,Afraid to attempt to drive to parts store to get code read.
Old 03-01-2016 | 10:47 AM
foxxfire7's Avatar
Pins seem fine.Wondering what could have cause limp mode,during replacement of electric connector O-rings.I did spray cleaner fluid in plug and socket to clean away tranny fluid.
Old 03-01-2016 | 06:24 PM
foxxfire7's Avatar
Pic?
The pins and connector looks good
Old 03-01-2016 | 07:09 PM
Steve Jr's Avatar
You did disconnect the battery, before pulling the electrical connection, right?
Old 03-03-2016 | 08:39 AM
foxxfire7's Avatar
I got this code yesterday. p0702. It say it's not communicating with transmission.Electrical fault.Also I've read on another trend that says the code has to be cleared in order to go back to normal.Anyone ever get this code before?
Old 03-03-2016 | 08:55 AM
foxxfire7's Avatar
No I did't Steve J.
Old 03-03-2016 | 10:33 AM
tighed1's Avatar
No I did't Steve J.
I didn't either. No issues due to that.
Old 03-03-2016 | 06:58 PM
foxxfire7's Avatar
I did spray and clean pins and connector plug with carb cleaner to clean it.No harm no foul,right?
Old 03-05-2016 | 11:42 AM
These are two common causes of your trouble code.
Weak battery or poor connections
Your Jeep Grand Cherokee's transmission can go into limp mode if you are using a weak battery. You should check the battery and cables from both ends, battery and car. If the limp mode is caused by bad battery then you can upgrade the Transmission Control Module software at your dealer. This upgrade won't make your battery better, but does not allow TCM to go into limp mode cause of under voltage. To avoid starting problems in future, you should still change the battery soon.
4. Gearbox plug adapter, OEM 68021352AA
Transmission plug adapter is located under the car and often starts leaking oil. Once oily, the plugs have bad electrical connection and transmission goes into limp mode and starts showing fault codes. It is easy to check the plug - look under the car and check if the plug is oily. If it's oily - get it replaced. Also check if the cables are fine - with time the insulation can crack and cables can short circuit. Then the outcome is again P0702 and limp mode. You can easily fix it with some tape.
02-29-2016 04:33 PM
foxxfire7
46
02-17-2016 06:30 PM
Geeny
02-10-2016 02:10 AM
Cirero
02-03-2016 01:33 AM
quejersey
02-02-2016 01:07 PM
