Oil leak
Re: Oil leak
Yes Mark, the little screws. The big screws should be torqued to 10nm / 7 ft/lbs .
Re: Oil leak
Y'know, it's always fun to read through a thread to see what's up.
BUT, sometimes it costs one work!
I have the replacement VC's, but haven't yet bead blasted them. I was, by coincidence, going to do that next week. I may be able to ship them in a couple of weeks. been pretty busy.
For a State employee.
180, I use VHT Wrinkle Plus:
VHT Wrinkle Plusā„¢ Coatings -- High Heat Coatings
(2) heavy coats for a nice wrinkle finish, 3 for a heavy wrinkle.
over 2 coats of self-etching primer:
Self-Etching Primer - Aerosol | Dupli-Color
following can directions.
After dissecting a number of leaking breathers, then cleaning and painting them, I have to stress the importance of removing every last bit of old sealant. And it is a bit harder than one would think.
My theory: the sealant is applied robotically and the breathers are attached the same way. The sealant always seems to be stuck quite well to the breathers, but pulls off the VC's easily. I figure it skinned over a little in manufacturing.
So, IMHO, one should remove the VC's and really clean them well before trying to apply the new RTV.
The VC gaskets are reusable so long as they are still flexible and resilient. Clean them before reuse.
But, at least they're cheap.
Steps:
1) Remove and strip/clean. This includes the M4 threads. Buy a tap if you need to.
2) Now, REALLY clean and degrease them.
3) Paint, following rattlecan directions. (I paint them with the breathers in-place, no screws).
4) Let dry 24-48 hours. Send wife shopping. Then bake @ 200F for 20 minutes.
5) Take a good, close look at how the parts fit together-you have to place a bead of sealant not just around the perimeter, but you need to seal the chamber (cross) flange and the bolt holes too.
6) Squirt a 1/8" bead on the "Figure Eight" of the BREATHER. It has the female groove. You need a bit larger bead on the bolt holes. I strike (screed) it flush, making sure of 100% coverage/groove fill.
7) Stick it together and screw it down. Soon. Don't make the MB mistake of letting it skin over!
If you use an "L-key" wrench, just tighten the M4 screws with the "short arm" of the wrench to limit torque applied. The extra sealant will extrude as you do. Wipe it off carefully. You just painted it!
Steps:
Personally I would turn the screws down a little at a time until they were tightened to spec, I am sure Max does the same. If not the seal will probably leak again pretty soon.
I even do that with the wheel bolts unlike the usual tire shop guys, after all it's not their car.
Re: Oil leak
When I last took mine to the local Chrysler dealer to have the wheels balanced on their dynamic road force balancer, I handed the tech my torque wrench with 17mm socket and extension set to 82 ft/lbs to put them back on.
He said he'd been doing balancing for 22 years, and no one had EVER asked to have the bolts torqued before. ( He actually said he thought it was a good idea )
Re: Oil leak
FUNNY !
unarel32
21
02-15-2016 09:09 PM
AustinGSrider
02-06-2016 04:16 PM
