Where to buy 74mm Throttle Body Upgrade
  #41 (permalink)
Old 04-28-2020 | 03:49 PM
Default Re: Where to buy 74mm Throttle Body Upgrade
Yes. You want the 113, you already have the 112
The 113 part number is A1131410125
  #42 (permalink)
Old 04-29-2020 | 12:23 AM
UrbanE's Avatar
There are a few in eBay
  #43 (permalink)
Old 04-29-2020 | 05:44 PM
AND, make sure you get a NEW "O" ring where the TB matches up to the intake. Also, you need to read up on a few of the .pdf's and posts. The more familiar with the upgrade, the better the outcome. You'll like the increase! Good luck!
  #44 (permalink)
Old 04-29-2020 | 06:18 PM
UrbanE's Avatar
GG, You are correct, I had forgotten about the spacer ring
If you go this route, an easy to procure the item is through Rob and Needswings (Link to the spacer attached
https://needswings.com/srt6-oem-thro...-gasket-spacer
part # A1121412480
$59.95
  #45 (permalink)
Old 04-29-2020 | 10:29 PM
NeedsWings's Avatar
The o-ring for the throttle body to be mounted to the NA grooved intake manifolds is
https://needswings.com/throttle-body...g-m112-or-m113
well, that is our version of it as we have them in a higher quality Viton rubber.
The "twist" spacer / gasket above is for the srt6 supercharger (not even used on slk32). they used to be $12 until Mercedes used them on the SLS and they jumped the price.
For the original post. yes you can pull the 74mm throttle bodies from eBay or junkyards all day long as Mercedes made several million cars with them so the market is there on them. The used TB's we sell we get in from srt6 or v8 Mercedes customers that then decide to upgrade to an even larger throttle body and we take their old 74mm tb's in on trade, I have more coming in than going out so only the better ones make the grade. I will not bother with ones with oxidation on the housing. Knowing their history gives us the piece of mind knowing they came off properly running cars and the confidence in them to pass them along to other customers. I sell very few used electrical parts, intentionally from experience, this scenario is one of the exceptions that I still allow due to the success.
4drturbo
01-03-2019 02:46 PM
waldig
07-31-2017 09:46 AM
Soma
12-14-2015 07:52 PM
Dnivek
08-07-2015 07:18 AM
ardenian
07-09-2015 02:08 PM
Quick Reply: Where to buy 74mm Throttle Body Upgrade
