3.7l engine discussion - swap?
i read on one of the threads that the 3.7l was identical to our engine and was simply bored out , some researching proved this to be true, some speculation on the idea that our stock ecu would work as well with some time . so this all sounds fine and dandy so far, but from looking at the numbers,it would literally only add 20 hp, for a full engine swap , so im hoping we can discuss if that version of our motor would have more upgrades available , and more hp output potential , perhaps even a turbo available to it ? although i do understand that our computers are the real issue with turbos and super chargers. i want your thoughts, is this even a worth while idea? im sure we could find these motors relatively cheap if we wanted too , but is there support for these things , how hard would it speculatively be ? could we breathe new life into our crossfires? GO!
Re: 3.7l engine discussion .swap?
Re: 3.7l engine discussion - swap?
what computer issues would we have do you think , the ecu would probably have to come from whatever was pushing it originally , then we would have to figure out how to make the rest of the car like it . logistically the only issue i see at first would be the cost of the new motor. this would be a pain in the butt'ole im sure plus the work, next the transmission, im sure ours is great, but realistically i could see it handling up to 300hp only thoughts?
wannaGOFAST
South Forum
08-14-2015 01:20 AM
BrenLW
08-05-2015 04:53 AM
