true dual exhaust help
Re: true dual exhaust help
I am in the same boat so I have been looking and one CAT back system that appears to eliminate the resonator is from Magnaflow. It's hard to tell from the picture which I think is generic but if you click on the product manual it appears that way and it has dual mufflers and tips.
This is mine. It has rear cats deleted and Smittys turbo tubes installed in spot. I added Magnaflow straight flow mufflers on the back end to quiet it down a little more and changed the tips to double wall stainless. They look similar to stock but better IMO and they sound great.
Thanks, I couldn't find your post Beaner. Nothing shows up with x pipe.
I found magnaflows true crossover X pipe on-line.
Anyone know what to stay away from on magnaflow's list of mufflers with tips in the link below?
MagnaFlow Exhaust Products - For Trucks, Suv's, American Muscle, Diesel, & Sport Compact Vehicles
Is the 6" body too big? I would like as large of a body as possible to keep the tone low. I would also liek to see if there is a true dual in and dual out.
on
Dynomax® Performance Exhaust | Mufflers | Ultra Flo™ X Mufflers
I've considered this muffler for my own setup...
beaner, im using your setup to tell my shop what i want, i already got the pipe. My question is did they make the inlet holes on the muffler larger when they welded the pipes to it? because i know the pipes that come on them are smaller.
Would you consider a hybrid of both?
This seems like a great idea. How does the dynomax sound compared to the magnaflow? Does it matter that the "X" is in the muffler vs. before the muffler to equalize the pressure?
I had always liked 4 chamber 3" flowmasters on my previous cars becuase they give that low tone gurgle sound.
on
I ordered the mufflers with 2½" in and outlet and I think we did open up the muffler inlet to go over the 2½" pipe. The tips were also expanded to suit. If you do it carefully it wont split, a little too fast and you will have to weld a seam up no big deal
on
There's a guy that put a Hooker on his SRT-6 (the muffler, not the hoe) and the sound is fantastic -- has that "gurgle" you mention. I think it was distantpulse, a member on here. Could be mistaken though.
Ok thanks, im an N/A so i got 2.25" xpipe thats the correct stock pipe size right? And i dont think im going to change the tips but any tips on cutting that thick material that the muffler is made of?
Here is what I put on mine.
Took everything off up to the cats and had a shop tube it up. Sounds great to me and others that have heard it. Might be a bit loud to you just depends on what you like.
on
Drove long trips, sat in traffic, Ontario emissions test passed with either engine installed, what more do you want. No fireball yet and it has been 3 years with this setup
It was a little raspy with the NA V6 but not any more.
Relax there ole timer, No issues, no sign of hoses getting to hot, you can grab the hose with your hgand after a long drive. Sometimes I put the plastic piece on, sometimes I don't. Yes I had to cut that plastic guard to make it fit.
Does anyone know the diameter of the exhaust on the SRT6? where there are still two pipes, and when it goes to one. I was thinking of making my own, I have a tubing bender and can get the correct size mandrel. Would probably buy an X member from magna flow, maybe their mufflers, too.
