Car & Engine SHAKES
  #41 (permalink)
Old 08-31-2012, 10:30 AM
Default Re: Car & Engine SHAKES
Originally Posted by alaxfire
Maybe a bad MAF sensor, or a bad connection to it in the harness.
The MAF sensor is in the plastic piece that the engine cover/air cleaner connects to ( at least on the N/A ), not sure where it is on the SRT6.
Unplug it and see if there is any difference, if no change then you found it, if it is worse, then it is NOT the MAF sensor.
EDIT - never mind, I forgot I had already posted this ........
Haha, yes you already posted it, but i just didn't looked back to keep it in mind.
I will try to have a look @ disconnecting the MAF sensor while the engine is running.
Do you think it could do something worse (like registering an error code inside the ECU) ?
  #42 (permalink)
Old 09-05-2012, 11:53 AM
So i tried to unplug de MAF sensor while the engine was idling and ...
The shaky behavior remains the same but the engine fan went ON and on full power + OBD error codes registered (3 error codes)
P0112 - Intake Air Temperature Circuit Low Input
P0102 - Mass or Volume Air Flow Circuit Low Input
P0102 - Mass or Volume Air Flow Circuit Low Input (Pending)
So basically, i reconnected everything, the fan went back to its normal state, but, the engine light was still ON so i cleared the OBD codes and everything went back to normal.
... Except, that i still have the shaky issues ...
  #43 (permalink)
Old 09-17-2012, 02:49 AM
Default
Hi ! I have the same exact problem and I don't know what else to do , I already spent 1300$ in this car and still the same ! Shakes sometimes and when it gets to hot ! Sometimes will even turn off at traffic light, changed the oxygen sensors , then fixed like 2 air lickings at vacuum system . The it was licking air in the exhaust something so they welled them and now light is on car shakes again and I don't know what else to do ! I've been at the mechanic everyday the last 3 weeks ! I'm so tired of this car and very disappointed !!! Did u fix yours ? Is it working fine now. ?
  #44 (permalink)
Old 09-17-2012, 04:32 AM
Hi,
No, i still haven't found the cause of the shaky problems.
By the way, now that i have changed the camshaft and crankshaft sensors, sometimes i can't start the engine, it cranks but doesn't turn on.
I'm thinking about replacing back the old sensors ...
I will have some time soon to look at the misfiring problems.
See you
ingsoc39
11-25-2019 05:44 PM
rayth
41
07-31-2019 04:02 PM
mhajek18
06-22-2015 04:54 PM
GraphiteGhost
06-12-2015 12:04 PM
krooner
Other Cars
09-11-2003 01:05 PM
Quick Reply: Car & Engine SHAKES
