Valve cover leak...
  #161 (permalink)
Old 01-06-2014 | 08:44 PM
KJN's Avatar
KJN
Default Re: Valve covers resealed, wont turn over need help
I resealed the breather covers and in the process split both hoses and am waiting for those parts. It has been 24hours since resealing the covers. When I tried to start it up, the engine turned over just a few times and then choked to a stop. When I try to start it now it just hums. It has power, everything electrical is working fine. Have I triggered some type of safety switch without the breather hoses?
I followed the steps suggested in the forum... I feel like I need to somehow reboot the computer? Any ideas?
KJN
  #162 (permalink)
Old 01-06-2014 | 09:07 PM
dtinker's Avatar
Default Re: Valve cover leak...
KJN:
What do you mean by" It choked to a halt" and it just "hums".
You said all electrics are working or does that mean that they are lit up? If battery is low it may not start. Is there any chance you dropped something in the intake, vac hose, or somewhere else. You mentioned the hoses split, you may want to check those again for fit ,etc. and for bits of hose in the intake. This should have been easy to do, I would also check the hoses and other hoses in that area of the Throttle Body.
  #163 (permalink)
Old 02-18-2014 | 05:23 PM
Indelibility's Avatar
Looks like both my breather covers decided to start leaking. Ordered the valve cover bolt kit from needswings, we'll see how it goes.
  #164 (permalink)
Old 02-26-2014 | 11:25 PM
JEFASOLD's Avatar
You probably just need to do the silicon gasket fix minus the wire brushes. Use something plastic to scrape any residue out and use care installing the bolts, they are aluminum, don't over torque.
  #165 (permalink)
Old 02-27-2014 | 06:07 AM
Be sure to use a gasket sealer that is suitable for the application - heat & vibration (see my posts #16 & #17 in this thread). Others have had success using different products, so your options are many. But I'm a believer that there is always one product that delivers optimum results (if you can find it) when proper assembly technique is followed. My breather covers haven't leaked since I did the original repair of the factory's use of an inferior product in conjunction with poor assembly technique.
Good luck,
  #166 (permalink)
Old 02-27-2014 | 06:08 AM
KJN
So what ended up being the solution to getting your XFire going again? Or is it still not starting?
  #167 (permalink)
Old 07-26-2014 | 01:29 PM
Coyote's Avatar
I'm in the process of replacing both the valve cover gaskets and the breather cover gaskets. Valve covers are easy, but I'm wondering just how to take these breather covers off (both have small leaks). Obviously, the screws need to be removed, but these things just don't want to come off. And, I don't want to beat on them. They are stuck on quite tightly.
Coyote
  #168 (permalink)
Old 07-26-2014 | 04:54 PM
Coyote's Avatar
Coyote
Figure it out, and they are off.
  #169 (permalink)
Old 08-15-2014 | 12:05 AM
roychez's Avatar
where can I buy the aluminum bolts for the valve covers?
needswing has stainless steel bolts.
my question is has anyone used these bolts?
  #170 (permalink)
Old 08-15-2014 | 04:58 AM
I used the ones from needswings.com, been a few months an all is well. Torque is key!
  #171 (permalink)
Old 08-15-2014 | 10:20 AM
meh03's Avatar
Funny note, I just did my valve covers and re-sealed the breathers. Best thing I found for scraping off the old sealant...the yellow crab leg breakers from Joe's Crab Shack!
  #172 (permalink)
Old 08-29-2014 | 03:24 PM
ijaved's Avatar
Do we have torque spec for valve cover head for NA?
  #173 (permalink)
Old 08-29-2014 | 04:13 PM
roychez's Avatar
10 N-m (7-8 Ft-lbs)
  #174 (permalink)
Old 08-29-2014 | 04:15 PM
roychez's Avatar
i did mine this past weekend. 7pounds no problems so far . Don`t over torque that`s the most important thing.
  #175 (permalink)
Old 08-29-2014 | 04:50 PM
ijaved's Avatar
Sweet thanks for the heads up. You just did the small valve cover not the bigger one right?
Marked in orange ? or the whole thing?
  #176 (permalink)
Old 01-29-2015 | 02:40 PM
LVXF's Avatar
Mine is leaking on the driver's side right under the oil fill cap. I'm planning to do the fix sometime next week. Can anyone tell me if there is a sequence to tightening the bolts/screws? For instance, do I tighten the E10 bolts first, then the M5 cap screws. Also, I understand the 7ft-lbs torque is for the E10 bolts, but how much torque for the cap screws? Also, there is a cap screw around a rubber bushing right above the oil fill cap. What's the toque on that? Its appearance seems different than the M5 screw in color.
  #177 (permalink)
Old 01-29-2015 | 02:46 PM
LVXF's Avatar
Dave,
I remember a couple of years back, we had a member that was told the same thing. To replace the whole valve cover!
I'm sure that it is only the common breather cover leak. I've now done 3 of them. The latest just this morning! If a dealership does it, they will remove the leaking cover, wipe off the surfaces, and stick it back together.
I wish I had taken photos. Sorry.
Not good enough. Once the breather cover is removed, I very carefully remove all traces of old sealant and degrease both the breather and valve cover surfaces that will be touching the sealant. And I mean really degrease. And remove the old sealant from the screw-hole areas, too.
Fill the groove in the breather cover with sealant and strike it off flush like screeding concrete. Just fill the groove, no more. Apply sealant around the screw holes. Just look carefully at how it fits together. Don't use too much-it will just come loose. Inside the engine. You are supposed to replace the M5 screws as part of the service procedure. Do it. They are aluminum and I would be very leery of using them again. McMaster-Carr carries them.
M5 X 16mm long. McMaster-Carr #92855A516
The torque spec is quite low, on the order of 10 in-lbs. If that much.
I also add lockwashers to this assembly. McMaster-Carr #90895A027
Be very careful not to plug the very small holes in the breather cap leading to the hose barbs. Those are our version of Positive Crankcase Ventilation vales. No valves, just properly-sized holes. It works fine so long as no non-synthetic oil is used. It will condense and thicken-clogging the holes. Just like in the VC's I just re-conditioned for a friend.
Please chime in, anyone, if you have more info.
Max,
Did you have to loosen the ignition coils? If so, how does one go about doing that? Or did you just slide the breather covers "around" the coils before seating them?
  #178 (permalink)
Old 01-29-2015 | 03:30 PM
LVXF's Avatar
Dave,
Max,
I just ggogled McM-Carr number, and it says the screws are stainless steel. Can you confirm?
Ed
  #179 (permalink)
Old 01-29-2015 | 03:34 PM
I can confirm that both Max and I have SS screws in the valve covers and valve cover vents.
( I got mine from Max )
The only issue here is that with SS, if you over-torque you will strip out the hole in the cover, rather than breaking off the screw as happens with the aluminum ones ......
  #180 (permalink)
Old 01-29-2015 | 04:35 PM
maxcichon's Avatar
To do this work properly, I removed the valve covers completely. The gaskets are re-usable.
I suppose you can do it in-place, just try your very best not to flick a silicone booger into the engine.
Good luck with that.
