Screen removal on MAF below intake on NA 3.2 M112
on
1 Post
Re: Screen removal on MAF below intake on NA 3.2 M112
Drove the car a little today. Removal of the baffles made a huge difference. I still have the 68mm MAF with no baffles, but does have the screen. Was going to take the sensor off and put it in the 74mm MAF, but could not get the tamper proof screws out. I will try and get the tool to get them out Sat. change it Sunday if possible. May just drill the center pin down and remove. The point is removal of the baffles seems to have made a big difference. Has anyone else done this yet?
on
1 Post
on
on
Does anyone have the MB or DC part number for that elbow with baffles below the MAF? I'm thinking of getting a second one to de-baffle in case I screw up the original one. This way I can do a swap without worrying the car would be down. Thanks!
A 112 141 0190 ( inside the info box )
A 112 140 0118 ( by itself outside the info box.
Google reports only Russian & German sites with a lookup to either part number.
If I were you, I'd be patient ( like I was ) and wait for a used NW CAI to show up for sale ........
( AND NO, YOU CAN'T HAVE IT ! - I'm keeping it in case I ever decide to get rid of the car ( doubtful, but you never know )
on
on
Thanks Lantana! I think I will try to pop all that off and do as you instructed. Hope I don't mess it up! Oh, one more quick q? Where the baffles are pressed in, is there an opening to outside or is it just a groove not going through to the outside. Thanks again!
Ahh, I see another response while typing this, thanks alaxfire!
My best stab at this is MB part#112 140 01 18, I got this from a 2000-2004 SLK parts list.
Mine has 2 numbers on it ( and no, I didn't remove it to look, it was already on the shelf after installing the NeedsWings CAI ) :
A 112 140 0118 ( by itself outside the info box.)
on
on
on
1 Post
on
1 Post
Well, I can tell you that the car seems to really run well.
I sent Eurocharged a message to see if we can get it in for a dyno run. Hope to hear back soon. I will post any info as soon as I get it.
I have also put the 2.75" intake tubes on and wrapped them with aluminized insultation on them to keep heat down. Thinking about insulating the bottom side of the airbox too, but I don't have anymore money now.
I'll send another message to Eurocharged to see what the schedule looks like.
on
1 Post
Just got back from Eurocharged. Jerry did a six pull Dyno run for me. My last RWHP was 198.1 on 07/15/11. The one today was 211.4 RWHP. TQ looks to be just about the same as HP. Today was cooler temp ,no doubt, but the two 2.75inch air intake tubes, removing the baffles in the elbow, removing MAF screen, and adding the 74mmMAF certainly added some HP (12.8) . Cost of the tubes, MAF, etc probably $125, not bad. If any of you are think ing of doing some or all these changes, I think you will be pleased.
Of course, the first thing to do is get a dyno tune, which everything keys off.
Originally Posted by TVT_DESIGN
On a stock M112 motor we've seen -3RWHP and .6 towards the lean end on the AFR. Not a smart move at all. Due to the location of the stock MAF the turbulence caused by the air entering a non-directed intake WILL (not may) result in negative consequences. Needswings intake works because it relocates the MAF to a more direct and unobstructed airflow path. The same design is used on the E, ML, and CLK class M112 engines.
Take the inof that I and many others have provided and use it the way you want to.
on
Originally Posted by Mrmiata
So the information provided here is actually incorrect based on reading through the thread. Correct? Just wondering if this should be done after I get my car back from having the Turbo installed.
Originally Posted by turbomar
If your going the turbo route, all you need to get is the 74mm TB. Everything else should be included in the turbo kit
on
Throttle body swap isn't high on my to do list. Just thought this simple mod might be benificial to the Turbo mod is all. I don't have a clue as to whether or not BEGi has decided removing the baffleing needs to be part of the turbo system install.
