NeedsWings na and srt6 CAI group buy
www.CustomCrossfire.com
Re: NeedsWings na and srt6 CAI group buy
Originally Posted by tylerxfire
feels great, so to ship this back what do i have to do and it is just the pipe and hose going back right. I didn't have anything included with a packaging sticker, is it the same one on the box?
Instructions ar 90% the same for both SRT & NA.
The only differing part is removing the MAF housing (black plastic piece which is a real b!tch to get to!). Start with the NA supplemental images, and piece those together with the SRT file - it's easy.
OK. All installed. Thanks for all the help Rob.
A couple of questions:
1) My engine light has not come on. Should I still reset by disconnecting the battery.
2) Will I feel a noticable difference in power. Or is it mainly pull through the revs. I have already deleted my cats and have a custon muffler.
3) Should the intake tube be warm/hot. i stopped and opened the bonnet and it was quite warm. i guess i just made the assumption that seeing as it was pulling in cold air it would not be warm/hot. When I say hot. it is not too hot to touch. just heat from being right up close to the engine.
otherwise. really happy. thanks heaps.
vio.
vio.
1. id like to see you do it but not totally necessary anymore, the pcm would just adjust quicker with a reset
2. you should be able to hear and feel the difference. now its not like a 150hp shot of nitrous hitting you in the back but its still noticable
3. yes it will absorb some heat from the engine bay, that is to be expected
