NeedsWings na and srt6 CAI group buy
Re: NeedsWings na and srt6 CAI group buy
dbg55...
You have a 05 Crossfire correct ??
This seems to not just be specific to the 04's then.
It's seems to be a "na" Crossfire issue.
Gary, Yes mine is 05 na.I disconnected the negative battery terminal. I only left it disconnected for two minutes. Connected and the light went off. I drove it for about 20 miles with no issue
Did a 1 hour disconnect and went 103 miles with no CEL on yet.
Don't know if its all good yet or not but she runs perfectly.
i know a couple of you n/a guys threw the light on the dash, ill have at least one n/a car here tomorrow to try and duplicate the issue and come up with a fix for it
I am sure you will find a resolution to this problem.
www.CustomCrossfire.com
Originally Posted by HyprLtH20
where can i get ahold of the tamper resistant star tool to unmount the MAF sensor from the intake? i cant find it anywhere.. the only ones i can find have 6 points and this screw needs one with 5 points..someone help me out!!!
we were only able to find them special order thru the snap on guy and they are like $20 each, we bought a bunch so i think we ended up paying 10-15$ each for them. did you lose it or is it still in the box that you havent opened yet?
i included one of those with all the n/a kits, it was in a white/clear plastic bag inside the small box with all the hose clamps/brackets/cdr
My Check engine light finally came on today and im in the midst of the 2 hour battery disconnect I also had a little bit of the idle problem when coming to a stop the idle would run on at about 1500RPM until the car was at a full stop.I had a Shelby Daytona that did that.
