All-in-one FAQ Thread - SpeedInnovation ECU Tuning Info/GBs/Specials
Re: All-in-one FAQ Thread - SpeedInnovation ECU Tuning Info/GBs/Specials
Originally Posted by mplc
OK... who has actually sent in their ECU, had it flashed, and happy with the results?
I've been trying to contact SI via email with no luck lately. Everything I send comes back undeliverable. Their website doesn't go into a whole lot of detail on our cars, IMO.
I'm trying to compare SI, Evosport, and Renntech.
i think at least seven of us have it, and yes that number is easily attainable. the ecu tune and pulleys should get you close, if not the shrick cams will get you there for sure, but they are very expensive. i put down 220 whp or so on a high reading dyno, probably more like a 205 on a more realistic dyno. the pulleys should get you about 212 whp if i had to guess, so you would be close.
Thanks...Mike
Without going FI, is it possible to get 250 HP, or 215 - 220 to the wheels?
Mike
Mike
As for HP I have not put mine on a dyno so I can't say for sure and as far as I know on this forum x'ed may be the only one that has but it is a nice gain.
You can do a search for the before and after stats.
Mike
Mike
https://www.crossfireforum.org/forum...ad.php?t=14554
Carl
Quote:
Originally Posted by SRT SIX
Interesting point. I assumed the VIN would match the SN of the engine. Can anyone answer this?
I've got a "L4-VON: 6377" with a 0105,with much space after that 6377,(Maybe the Engine Mfg Date?) on My SRT6 Window Sticker, next to the Reg VIN: is that it?
SF
SF
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
