I need a SRT6 Engine computer ECM
Re: I need a SRT6 Engine computer ECM
The question is, how did you determine it's an ECM problem? Mechanic, friend or your own diagnosis? Read the attached by clicking on the attached link and you will see the culprit that is causing your issues related to starting along with other issues. The Relay Control Module (RCM) is the culprit.
Good luck...
Dennis
DTMenace
Engine Control Module - CrossfireForum - The Chrysler Crossfire and SRT6 Resource
If you had elaborated in your first post about the engine conversion, I would never have responded, thinking you owned a SRT6 model. Please provide more details to your posts in the future.
Dennis
DTMenace
Reach out to the Mercedes Swap Shop. See if he can help you.
https://themercedesswapshop.com/?page_id=257
I used the existing NA Harness and discovered a few small surprises after in swapped engines.
The internals are different, as well as has been posted already. NOT all of them BUT you're going to have a helluva time with this conversion (and it might only work for a few WOT's). I believe it'll be less expensive to just go buy an SRT-6. The monies you save will far out way the time/effort/and monies you spend to learn this lesson that quite a few have already learned. Have fun either way!
PS: IF you wish (I recommend), spend some time researching this within the forum. It has been brought up quite a few times over the years...
The one I can immediately recall is the secondary air pump they’re different units with different wiring. And different location. The manual does a good job of calling out the electrical. You need power to the Intercooler water pump.
it's driving the coolant though the small rad located lower front middle. Did you acquire the parts from one or multiple donor cars.
Are you using the existing 3.2 that was in the NA???
We all want to know
We all want to know
LesM (10-13-2022)
bucksarrow
04-23-2017 11:54 PM
FUBU
08-26-2010 09:29 AM
CrossfireLTD
06-03-2007 09:36 AM
