large water leak on passenger side when raining
Old 06-24-2018 | 04:59 PM
king happy's Avatar
Default large water leak on passenger side when raining
left my roadster outside for about 30 min in a rain storm and had about a 2 quarts of water on the passenger floor . pulled cover off passenger side under dash , the one with the holes , it was wet . Then pulled the bottom over off the fan and it was full of water . there was water every where . its diffidently dripping from under the dash .
Any idea what is causing this ?
Old 06-24-2018 | 05:28 PM
Sussudio's Avatar
Default Re: large water leak on passenger side when raining
Check to see if there are leaves or other debris clogging the cowl. Common problem for the Crossfire’s
Old 06-24-2018 | 06:14 PM
Sure sounds like the drains under the cowl are plugged. You will have to remove the wipers to remove the cowl. It is best with a small puller. There are instructions on here somewhere for replacing the alarm siren which includes directions for removing the cowl.
brewski
05-27-2019 01:33 PM
onehundred80
U.K.
05-22-2014 08:30 PM
Loumarino800
03-30-2013 01:30 AM
Mighty Quin
U.K.
05-21-2010 03:55 PM
Wedge
Racing
03-10-2009 02:02 PM
Quick Reply: large water leak on passenger side when raining
