NeedsWings headers/downpipes - need some opinions.
I've been tossing a few exhaust setup ideas around in my head for a while now, but am having trouble deciding what to do.
I'm currently running a stock exhaust setup, with the exception of a custom axle-back to a Megan Racing M-RS muffler. Pretty standard issue stuff, and sounds stock more or less. I'm looking to get a little more sound and of course, a little more power without breaking the bank or making the car sound too obnoxious. I don't mind an aggressive exhaust note but I want it to be crisp/smooth, not raspy and overbearing. With that being said, here are the options I am considering.
- NeedsWings headers + NeedsWings catless downpipes + retain factory resonator
- NeedsWings headers + factory downpipes + delete factory resonator
- NeedsWings headers + factory downpipes + retain factory resonator
- NeedsWings headers + custom downpipes deleting 2 of the 4 cats + delete factory resonator
- NeedsWings headers + custom downpipes deleting 2 of the 4 cats + retain factory resonator
- Factory headers +NeedsWings catless downpipes + retain factory resonator
- Factory headers + custom downpipes deleting 2 of the 4 cats + delete factory resonator
- Factory headers + custom downpipes deleting 2 of the 4 cats + retain factory resonator
Re: NeedsWings headers/downpipes - need some opinions.
Good options listed! My only question if you go with #7 (my gut suggestion), will you pass emissions testing with this setup? All your options will result in the same end question, right? Number 7 seems the most popular for the bang/buck (especially if your state tests emissions). Good luck with your mods!
Read the posts concerning the exhaust, there is very little power to be gained no matter what the options. Concern yourself with sound and skip the big buck options.
There will never be a concensus on the "best" exhaust setup for this car. There's also no real cheap option when you consider the price of NW headers or downpipes. I think the person with most experience trying different setups is Les. I think he said he gained 40 HP with long tube headers and downpipes, but no emissions tests. Don't quote me on that. Back in 2011, the suggestion was to remove the resonator and rear cats. If I had the $$$ lying around, I'd do option #1 and delete the resonator. But we don't have emissions testing in Florida....
If you keep the stock resonator and muffler the sound stays civilized regardless of what else you change. The majority of power gains are from removing the cats. My advice is the NW cat delete downpipes and keep the rest stock. The NW downpipes bolt to the stock supports. You can remove them and go back to stock in around an hour if necessary. I installed them myself in a condominium basement on jack stands. First time took a lot longer but the second time an hour.
Les
Les
Well, you just spent many times more than I did on mine and I seriously doubt that it would have better sound and/or more power than I do, except of course with cutouts open. Then again, where can you drive it like that except a track? My total cost for a great sounding exhaust was less than $200 and I would match it for power and sound with anything I have seen on any other Crossfire.
No argument with that. I'm just saying that with a little thought and good design, you can have an improved exhaust without breaking the bank. I'll let the guys at Carlisle weigh in on what they think of mine.
Jeff, what muffler are you running ?
Here is my setup. I deleted the back CATS went directly into a "Y" with a 3 inch outlet. Then a 3 inch pipe through a 3 x 12 inch resonator directly to the stock muffler, removed the OEM resonatot, then into "big" round tips. Sound is deep and throaty until the SC kicks in then it's almost Ferrari like. I eliminated all the twists and turns, a lot of weight and get a scavenging effect since the "Y" is as close to the engine as I could get. Luckily I have my own welder and pipe bender so that saves a ton.
Yeah, I think I am going to forego the NeedsWings headers/downpipes and go with a more economical options considering I'm not really after huge power gains. Just want to "un-cork" the exhaust system a little bit and get a more aggressive exhaust note.
I have the needswings downpipes and it deleted all 4 cats. It now has a very deep sound. I'm ordering the MRS muffler next week . Id personally go with downpipes, headers , and the MRS muffler while keeping resonator. Do yo have any sound clips of your MRS muffler ? How does it sound In your opinion ?
Honestly, it really sounds no different than stock. At least from inside if the car. I'm sure that'll all change when I delete the cats/resonator, at which point the M-RS muffler will probably sound a bit different than if I were to delete the cats/resonator and retain the OEM muffler.
Having to deal with emissions definitely throws a curve ball my way and limits my options.
I considered doing cut-outs, but at the end of the day I just can't justify running them. And I already have a Megan Racing M-RS muffler, so no need for me to change my muffler setup. But I appreciate the input.
But don't get me wrong, I agree that there is such a thing as too loud. My roommate has a Camaro ZL1 with SLP long-tubes, no cats and a Corsa cat-back and it's a bit too obnoxious for my taste. It might be un-American for me to say this, but I'm really not a huge fan of the way built/cammed V8's sound. It sounds mean, don't get me wrong, just not my cup of tea.
I am choosing Option 2, deleting all 4 cats and the rear resonator, but ADDING 2 Magnaflow 5" bullet mufflers with 2.5" inlet and outlet, with exhaust tips. If these are too loud, I will add some small resonators for tip of exhaust. Any opinions on whether this will be too loud? I want a mild loudness, not a raspy loudness.
Birder Ganson
05-31-2016 09:21 AM
