Mounts
Mounts
Hi everyone I'm in need of new motor& tranny mounts does anybody knows if this ones fit just like oem or it requires special install thanks in advance by the way it's for my 05 srt6 or if you know which one do for same affordable price pls share links or info
http://m.ebay.com/itm/Mercedes-Engine-Motor-Mounts-Transmission-Mount-Lemforder-OEM-2200617-3pcs-/151570146411?nav=SEARCH
Re: Mounts
I bought my last set from AutohausAZ and they fit perfectly.
If you launch quite a lot you may want to consider the SL55 mounts. Will fit and supposedly more robust, but I havent tried them.
AutohausAZ.
<a href="http://www.autohausaz.com/search/product.aspx?sid=3dwhyf45jsdnqrabk4yohsfk&makeid=8 00016@Mercedes&modelid=1429499@SL55 AMG&year=2004&cid=20@Engine Parts, Seals %26 Gaskets&gid=5552@Engine Mount">SL55 Mounts</a>.
AutohausAZ.
Re: Mounts
I posted a link to these some time ago....
Mercedes W220 E55 S55 Engine Mount Driver Left OR Passenger Right | eBay
Re: Mounts
Many have tried them and succeded.
I havent.
Just did a model check result....
".....This part is compatible with 1 vehicle(s) matching 2004 Mercedes-Benz SL55 AMG Base Convertible 2-Door. Compatibilities are defined by the seller for vehicles typically fitted for operation within the original listing country. ..."
It would be good if someone who has successfully tried the SL55 mounts to chime in.
To help out I dug up some old posts for reading/confirmation
the needswings ones are stock and exxie.
https://www.crossfireforum.org/forum...or-mounts.html
https://www.crossfireforum.org/forum...65k-miles.html
one of the statements...."The V8 mount and the v6 mount look identical, I had one in each hand and could not tell the difference other than the part number... Since the v6 is lighter, my guess will be less than a ¼" difference in height if you were to put the v8 mounts with your v6... So do some more calculating..."
I havent.
Red Runner
12-27-2023 10:11 AM
Chiminoul
11-14-2015 10:40 PM
blackpepper
08-31-2015 12:18 PM
