Peeling Srt6 Wheels
Old 11-02-2015 | 07:44 PM
bbsrt6's Avatar
Default Peeling Srt6 Wheels
So, it seems like the clear coat and paint is starting to peel off my wheels. One of my wheels is in bad shape and I'm pretty sure that it's due to this crappy Eagle One wheel cleaner that claims to be safe on clear coated aluminum wheels. Anyways, I'm trying to fix the problem and I got a quote from one of the few good wheel repair shops in my area and they want $220 per wheel. I'd rather try the cheaper route first and do it myself. I've seen a couple wheel repaint kits online but I'm not too sure about them. Has anybody had success with any of these repaint/repair kits?
Old 11-19-2015 | 12:23 PM
rip it's Avatar
Default Re: Peeling Srt6 Wheels
My left front wheel is doing the same. The other 3 are fine. Probably not your wheel cleaner.
Old 11-19-2015 | 06:53 PM
bbsrt6's Avatar
yep, that's the exact same wheel that's peeling on mine. I guess it could just be the constant brake dust buildup on the front wheels. I think I'm just gonna try cleaning the wheel, sanding the bad spots down, and then spray those spots with clear coat lacquer. Will see how that works. If it looks like crap, I'll end up completely stripping the wheel with some aircraft stripper, sanding, and respraying a couple layers of clear coat lacquer. From the limited research that I've done, this seems to be the cheapest and easiest fix for aluminum wheels. The thing I'm worried about though, is the one wheel turning out great, but it not matching the rear wheel.
Shaynes848
11-02-2015 06:25 PM
AndrewKeiranMcAllister
11-02-2015 04:54 PM
silverbluevt
11-01-2015 10:17 PM
rmcdaniel12
10-31-2015 11:21 AM
jaws
10-27-2015 09:35 PM
Quick Reply: Peeling Srt6 Wheels
