DATALOG: What should TPS read?
My TPS reading seems to be RPM related. Even though I am at WOT through the pull the TPS reading goes higher with the rpm peaking from 85-100 depending on whatever, I know not! Should it read 100% from any RPM? If it did sooner would that change any other data like timing? ETC.?THX
Re: DATALOG: What should TPS read?
The software that comes with the Euro-Flash. It must be slow as it only gets high, mid 90's near the higher rpm range. I would think it should read 100% whenever the pedal is down to the floor. The car runs fine but right now the 90*+ temps in SW Florida era taking away what feels like 30HP!
Jerry said I could not read the TPS so I reminded him I was using the E/C software.
Maybe I could use a new TPS, the one that goes on the TB? The gas pedal assembly was replaced last September when I bought the car, an SLK32.
I would like to know what timing is normal too. Mine is all over the board down low but usually ends up around 19-20 at peak RPM/TPS. I have questioned why these motors run so little timing at light cruise, maybe 30-32 degrees. That can't help mileage but I guess is what these motors need to have.
You could get yourself a Bluetooth OBD2 plug from China for $9 incl. Shipping here and then download Torquepro from the appstore ...$5...and see what readings it gives you.
But most probably the same.
My update frequency on the wireless+app is about 1second but I'm reasonably happy with that.
BTW I use a mini usb BTdongle from Amazon, not much knee room in a crossie so need the short one.
Also Torque Pro only works on Android. (have it on my phone).
Is the TPS on your foot or the throttle plate ? Can see the FBW logic dialing it in as the revs climb and it needs "more".
rampntlion
21
02-11-2019 08:18 AM
blackpepper
10-04-2017 06:09 AM
johnnycross413
03-04-2016 04:49 AM
