High stall torque converter vs 3.27 gears
Has anyone actually installed a high stall torque converter?
For slightly harder launches, I know we have the option of the 3.27 gears (6.5% lower gearing than 3.07). The RPMs are already fairly high cruising down the highway at 75 mph though. I don't really want to raise them higher.
It seems a high stall converter would be a good way to get out of the hole quicker at the dragstrip, but still keep the same cruising RPM (the converter locks up when cruising, no slip).
I was reading some threads over on MBworld and they really sparked my interest. I would consider it a good mod if it were worth 2 tenths or more in the 1/4 mile.
I talked to a friend of mine who runs a 10 second new Challenger on NOS with a built drivetrain. He runs a 4200 stall converter. He said a high stall converter is a "game changer". With the amazingly flat torque curve these 32K engines have, we wouldn't want anything that high. The 55K MB guys sound happy with the 3000 stall converters. Since we all use a MB 722.6 / Mopar NAG1 transmissions, there are LOTS of shops that can supply them.
link1
link2
link3
Once you get into the higher cost per ET mods, like stacked pulleys, intake manifolds, and headers, a high stall torque converter starts to look pretty attractive.
link1
link2
link3
Re: High stall torque converter vs 3.27 gears
talk to Bryan....with the turbo charged SRT. I think has one.... Eurocharged was selling them. I can't hook up now coming out of the hole, so going even higher rpms isn't going to help me...and I want a 3.47 rear end.....if we ever figure out the tcu tuning....
I have been running the Eurocharged TC for about 6 years now. Driving normal, you feel no difference than the stock converter. Blip the throttle and hold on. My converter flashes to about 3000 rpms and I can get about 2600 out of it before I over power the rear brakes at the track. I am probably pulling my engine out again shortly, and may put my converter up for sale and go with something a little looser since I am turbocharged.
Thanks for the input everyone!
I can brake stall my factory converter to 2300 RPM MAX. But I have a stacked supercharged setup that makes a lot of low end torque. Actual stall speed varies with the torque applied. At the track I won't brake stall it over 1800 RPM or I risk pushing farther into the beams and red-lighting. You might want something a little looser with a turbo.
I was going to say the same thing, but doc beat me too it.
Doc - There is one person ahead of you that has shown interest in the converter, but I will keep you informed.
Matt - The Hoosier 275/45R17 Drag Radials work great for me on a prepped surface. I launch at about 5psi, and hit 25psi before the 60' and the tires hook very well. Just a little heat in the burnout box, but not too much as they can/will get greasy.
Not a problem Bryan....not that I really need it....but, nice to know what Hoosiers to buy to replace my ole Hoosiers....275/45/17's.... Hopefully spring will have time to sort out the rear end gear change, TCU, and put the drag radials on....and see what we can do....
OK, thanks. I knew there were a couple of different bolt circle sizes at least. A lot of shops seem to want to to send yours in and they modify it as needed. Should be OK then, right?
I have my engine out, and I am willing to sell my Eurocharged converter if you are interested.
doc Rudy has the 346 rear ,, i tested it for a little over than a month, it works great, i am going with the one I got from Rudy, and he has another one ,,,u could be first to put the 346 behind a v6,, you will like it. jim
crossfireusa
10-28-2015 12:03 AM
jimf
10-10-2015 10:22 AM
