Check engine light back on ??
Old 10-10-2014 | 06:30 PM
fastfred's Avatar
Default Check engine light back on ??
I went to get lunch today and the check engine light is back on so i stopped by the o'reilly auto parts to have them try and give me a code of whats up and they do NOT check codes anymore a corporate thing is what he told me ..........im not having very good luck with my srt-6 it seems its one thing wrong after another.....im putting a lot more money into the repairs of this car than most i have had and i now only have 62k miles on it....
Old 10-10-2014 | 09:12 PM
Default Re: Check engine light back on ??
Get one of the cheapy code readers or an ULTRAGAUGE and read the codes yourself!
A CEL is often NOTHING to worry about, hell, a bad gas cap seal or broken solder on the RCM can throw a code! With mine, I had 100,000 mile old spark plugs and it was throwing misfire codes EVERY TIME I drove it. Plugs and plug wires and I'm good!
Old 10-10-2014 | 10:31 PM
Check engine lights are nothing to panic about. Try Auto Zone. Or buy yourself a cheap reader. Hell, try disconnecting your battery cable for a few minutes and see if it clears itself. Sporty cars do require a little more maintenance than the boring cars...just sayin'
Old 10-10-2014 | 10:45 PM
JEFASOLD's Avatar
Buy an inexpensive code reader from Harbor Freight, you can get a fairly good one for right around $100, but as low as $59, you will not regret it. One of the best investments that I've made.
Old 10-10-2014 | 10:59 PM
The best 60 bucks you can spend
Many here including myself have one of these
Reads you codes and allows you to reset them everytime
Plugs into your OBD2 port and can be left connected at all times to monitor nearly 70 functions
UltraGauge OBDII Scan tool & Information Center
Old 10-11-2014 | 04:23 PM
fastfred's Avatar
It's my damm air pump again went to a repair shop and the code is for the air pump again and they checked it for free....... D J already repaired my RCM ... ( thank you DJ)....When cold start I can here the air pump turn on for about 10 sec and turn off .... I have reset 4 times and the Check engine light comes back on and I now know it's thowing the air pump code....what's next ? Maybe replace the air pump?? May be it's going on but not working right??
Old 10-11-2014 | 04:27 PM
fastfred's Avatar
Oh and thank you all for the info on the code reader I will get one
Old 10-11-2014 | 05:32 PM
philosophico's Avatar
Might be time to just buy a new RCM. I did for mine when I couldnt get it soldered. As long as your air pump works, it is likely the relay. Sounds like it went bad again. One quick way to check is to open up the relay and look for bad solder points on the air pump relay and check and see if that bronze color plate with the lil magnet dot is burnt up. If it is the air pump relay is no good.
Old 10-11-2014 | 06:50 PM
I agree. recheck the relay. If the pump is running, it must be fine. check connections around the pump, but it is being powered. Maybe the new relay is stuck....
Old 10-11-2014 | 07:07 PM
fastfred's Avatar
I'll try checking that out ... Thank you
Old 10-11-2014 | 07:24 PM
fastfred's Avatar
I thought DJ put new points in but anything is possible but the air pump got so. Hot I could not touch it and the smell of buring wires was strong ..so even know the air pump is turning on it may have a short or someting not working right in it throwing the code?? If I had the money right now I would replace both hahaha.. ( this is good info thank you)
Old 10-11-2014 | 07:36 PM
fastfred's Avatar
I have thank you for your input
Old 10-11-2014 | 08:05 PM
Ok, wait a minute.
You say the pump is running? Then the RCM and relay are fine.
You say the pump is getting hot? Sounds like the pump itself is not right, it's airway is clogged (the additional load on the motor would cause it to get hot).
If the pump is running, forget about the damn RCM, the pump itself is bad/clogged/stuck/etc.
And the P401 code is no bid deal, anyway. It just means your cats don't heat up as fast and your emissions are SLIGHTLY higher for a bit until the cats heat up. No big deal. I do'nt like to drive a car with the light on, but it's not the end of the world or anything.
Old 10-11-2014 | 08:32 PM
tighed1's Avatar
Fred. Not the RCM. You have a brand new relay.
Mark is right (this time ). Need to look at the pump.
Old 10-12-2014 | 12:09 AM
fastfred's Avatar
Thank you DJ for your input the pump is what I was also thinking as it does go on but I'm thanking it has damage form over heating .... the one I was going to buy on eBay sold out so if someone has one for sale I would be happy to buy it!!!
Old 10-12-2014 | 12:21 AM
fastfred's Avatar
Ok, wait a minute.
. Thank for your input yes it did get very hot the 1st time ....I'm looking now to replace the pump as I was going to do at the start of all this going down but I followed some good advice as I needed work on the RCM also ....again thanks for your help ....
Old 10-12-2014 | 06:44 PM
Does the air pump run and cutoff or does it stay running and you have to unplug it?
Old 10-12-2014 | 08:39 PM
fastfred's Avatar
Yes it runs and turns off after about 10 sec
4drturbo
01-03-2019 02:46 PM
tom2112
12-01-2015 09:02 AM
tom2112
07-12-2015 04:41 PM
tom2112
07-08-2015 08:13 PM
eastside08
06-07-2015 07:21 PM
Quick Reply: Check engine light back on ??
