Supercharger Stopped!
Re: Supercharger Stopped!
YEs, the fuse could be the problem. The S/C will work until the temp is hot, even with the IC pump not on. When I changed my pump out, I thought it wasn't the problem after because it still wasn't working. Ended up the old pump blew the fuse.
I believe a bad air intake sensor can cause the S/C to disengage also. Same theory, the car believes the intake air is too hot, so disengages the S/C clutch to get cooler air and protect the motor.
o55ie18
10-05-2015 05:50 PM
tritongreen
09-18-2015 07:32 AM
