Need some sage advice... what to do?
Old 07-04-2014 | 10:24 AM
MiamiTVR's Avatar
Default Re: Need some sage advice... what to do?
I am not a mechanic but recall a very similar symptom when my Audi's cat went out. I lost about 100 mph off my top speed.
Old 07-04-2014 | 10:53 AM
Padgett's Avatar
First I connect a dongle ($12) and use Torque ($5) on my phone to check for reported faults. If you were reading misfires, you were doing something similar. I would have expected an erratic idle to set a count since it is reading rpm deltas but may wait for closed loop before starting.
Have to keep in mind that the elecronics in these cars are really pre-milennia and in the infancy of OBD-II. When I see something like this I run a fuel pressure check to see if in spec. If OK and the tank is under 1/4 full I check for water in the gas (both can be done at the fuel rail). Note: since they started putting ethanol in the gas, I rarely see water any more. We used to "winterize" gas by adding "gasoline anti freeze" - ethanol - to the tank).
Next I start looking at secondary ignition (ICM, coils, wires, plugs since neither fuel pressure nor water nor secondary ignition will normally set a code in early OBD cars.
Where to go from there depends on what you find. YMMV.
Old 07-04-2014 | 12:12 PM
sounds like a simple CPS issue. But nothing is ever simple when looking for electrical gremlins...
Old 07-04-2014 | 12:18 PM
JHM2K's Avatar
OR... rather than guess... He will have Mercedes' finest technicians tap into it and they can pinpoint exactly what's wrong with it.
At this point, I'm just happy to learn that it appears to be something completely unrelated to the problem that I paid to have fixed. Now that it's in the hands of Mercedes, I really can't offer much in the way of helping him find cheap parts because they will likely want to provide them. Hoping it's something simple like an unplugged connector or vacuum line.
At the end of the day, I appreciate Bruce's friendship and I want to do everything I can to keep it intact. That's why I made the trip up there last night... I never want my integrity to be called into question.
Old 07-07-2014 | 11:10 AM
JHM2K's Avatar
Monday update:
Apparently Mercedes' finest are stumped as well -- ZERO codes.
So, now we're all befuddled.
I guess the next order of business is to have Eric @ Mercedes call Buckhead and let the professionals chat it out... I'm out of ideas/suggestions.
Old 07-07-2014 | 01:13 PM
autumnmass's Avatar
Your a great guy and definitely deserve a pat of the back -- that's a class act you are doing -- willing to help out the new owner.
Originally Posted by JHM2K
Wanted to give you all an update on the situation...
So tonight, I drove up to the airport to meet him. Wheels touched down at 6:20, and by 6:30 we were looking at the car.
The good news: It does NOT appear to be related to my other issue that was fixed by Buckhead.
The bad news: We still don't have a clue what the problem is
I got a clearer story tonight as to what happened at the moment of failure... he said he had made it into the parking area just fine; it was only the last 15 feet (literally in front of the parking spot) that the failure occurred.
Failure "felt" the same as my old misfire problem. But here's the kicker -- no CEL.
I plugged in the DashDaq and tried to pull codes... nothing. 0 pending MILs, 0 DTCs.
Tried to start the car, and it cranks and fires right up -- and settles right into a ~450 RPM idle (lumpy). If you give it, say, 10% throttle... the idle smooths out and you can maintain 1,000 RPM and it will be fairly smooth. Give it ~25% throttle, and it falls on its face. Literally won't go above that RPM.
Engine was cold, hadn't been run in nearly a week so we know it's not a heat issue. Something broke -- a sensor, throttle body maybe? But it won't idle and won't take anything more than 25% throttle.
Conclusion is that he called AAA and had them come to pick him up. He is going to have the car dropped off at Mercedes of Nashville (he knows the lead SA) and hopefully they can plug Star-DAS into it and see what's what.
Still bummed for him... I hate that he only got 110 miles of enjoyment out of it before it gave him an issue. You simply never know.
So, I plan to stay in touch and "guide" him to the right fix (and cheaper parts).
Not going to abandon him and simply say "good luck". Not how I operate.
Cheers,
Old 07-07-2014 | 01:54 PM
JHM2K's Avatar
Thanks man. Just trying to give him the same treatment that I would appreciate.
I spoke with the Mercedes tech earlier, he said he thought the car was running entirely too rich. I told him that shouldn't be an issue at all, since the AFR's (in open loop) are 12.5-11.9.... and while the car is simply driving around, the ECU seeks stoich (14.7).
I'm still standing by the suggestion that a sensor (TPS, CPS, etc) had a sudden immediate failure. The car was running great, then had an immediate, sudden misfire that has not gone away since the failure occurred. So, it's not a heat-sensitive issue. MB tech says fuel, but until he shows me a black spark plug, I'm not buying it.
I put him in contact with Buckhead, so hoping they can work together to glean the needed expertise.
Old 07-08-2014 | 10:14 AM
sk8erjosh09's Avatar
Hey John, sorry it took me so long to find time to look at this thread.
First of all, you're a great guy doing the right thing. This is exactly what I'm working at and will do when I sell. A nice clean perfect as possible car and assistance so that they don't break the bank everytime they need something diagnosed.
As far as the issue, I'm wondering why the tech said that they couldn't pull any codes... That literally makes no sense because the first thing to pull on DAS if there's no CEL is the "Full list of Fault Codes and Events" on the home screen of the ME. It pulls up every single code that has ever been thrown on the car including stored codes that may clear themselves after the problem goes away.
It's hard to say why it would happen and then go away, but Buckhead at this point knows the car. I put my money on them being able to come up with something. Tuning is crazy from what I'm trying to learn on MB's and there is always a possibility that they changed the wrong value on coding somewhere. Happens all the time.
Old 07-08-2014 | 11:06 AM
JHM2K's Avatar
Thanks Josh.
What has me really stumped is how PERFECT the car ran for the three weeks in between the Buckhead visit and the failure. Tunes don't just "go bad"... if they work, they work.
Agreed that it's... unusual... that MB couldn't pull codes. If nothing else, they should have enough basic mechanical knowledge to be able to diagnose w/o needing Star-DAS to hold their hand every step of the way.
I mean, my car only has three mods on it -- a CAI, a pulley, and a 255lph fuel pump.
Everything else is factory.
Old 07-08-2014 | 11:32 AM
Has anyone just tried the obvious and replaced the CPS? Remember when Oledoc suggested your injectors were over heating and you said you had never heard of that before? Sometimes the obvious is what it really is..... it is a cheap and quick thing to rule out, and it does have the symptoms. And you just stated on here that a an MB person told you there were recalls on CPS sensors.... But, I may be all wrong... I have had an AIT sensor come loose and cause all kinds of missing rough idle problems as well.... The boost will sometimes break the tab, and push it out enough to leak....
Old 07-08-2014 | 11:42 AM
JHM2K's Avatar
Yes, at the end of the phone conversation yesterday, I advised the tech to replace the CPS as a "cheap" experiment. I haven't heard back from them since. Is that a good thing? Here's hoping
And yes, you were 100% right. Injectors WERE overheating, and I had never ever heard of such a thing prior to this. My thoughts were, fuel is flowing through them... HTF are they getting too hot?!? Hahaha
You win two internets, sir.
Old 07-08-2014 | 11:44 AM
you did say, sage advise..... I do qualify....as a sage...others call my worse....
Old 07-08-2014 | 11:56 AM
JHM2K's Avatar
Well-played
Old 07-08-2014 | 01:11 PM
Thanks Josh.
That is unusual for sure. Is there a possibility of a bad fuel filter?
Old 07-08-2014 | 01:28 PM
JHM2K's Avatar
At this point, Santa Claus putting a banana in the tailpipe is a possibility
If it ain't chickens, it's feathers.
Old 07-08-2014 | 02:51 PM
nickwe21's Avatar
Sorry I can't be much of help here. I hope they will figure it out and I'm extremely happy to see people on this forum get together and help each other out! This is why this place is great and a joy to read!
As for my question - I keep hearing about the TORQUE smartphone app. What except for check engine error codes (and probably other diagnostics codes like airbag, alarm etc,) can this tool do? And where to get the plug needed as a connector? How much does that run?
Old 07-08-2014 | 06:58 PM
I'm not into smart anythings but I can do 'search' on my Commodore 64.
Click
  #38 (permalink)
Old 07-09-2014 | 07:54 AM
32krazy!'s Avatar
john you have to remember its unlikely theres a single "mechanic" at the benz dealership. theres a garage full of "techs" but if the computer doesn't tell them what to do they are lost. add to the equation the embarrassment of having to work on a chrysler in full view of all his peers and i bet he barely plugged the star das in before giving up all hope. send it to jason in atl and let actual mechanics work on the car
  #39 (permalink)
Old 07-09-2014 | 09:35 AM
JHM2K's Avatar
All valid points...
I've recommended Buckhead a dozen times but the new owner seems resistant to sending it that far away... Which is interesting, because before the sale he mentioned going to ATL all the time.
It's Wednesday and I haven't heard anything from MB or my buyer, so maybe they fixed it... who knows.
  #40 (permalink)
Old 07-09-2014 | 10:07 AM
Padgett's Avatar
OK fols, there hane been several threads in the past on Torque Pro & the TorqueScan plugin (both available from the Play Store) and OBD-II dongles (I have a Mini to maximise knee room likethis ).
Use the TorqueScan plugin to find what parameters the XF supports. (Note it does identify itself as a Chrysler and not a MB) then add to the RealTimedisplay.
You can try using the enclosed torquedial.dat file I use on my phone's 3.5" display. With a 8" tablet I can put all on the same page.
Note: I had to rename torquedial.dat to torquedial.txt to add as an attachment. Change back to .dat and copy into the .torque directory (may need to enable hidden files to see the directory).
I check for fault codes & run the full test sequence occasionally to see what is happening but usually run in realtime mode.
ps can run it and play music or run the sat-nav at the same time but shut down completely when not in car to keep it from draining power.
File Type: txt
Quick Reply: Need some sage advice... what to do?
